Mouse pointer sensitivity
Has anybody found the perfect setting for the mouse pointer using the touchpad? It's very sensitive and hard to use.
(07-22-2020, 10:51 AM)rfm83 Wrote: Has anybody found the perfect setting for the mouse pointer using the touchpad? It's very sensitive and hard to use.
Let me just add that what I'm looking for is to change the sensitivity when the pointer is on any icon or button. It seems to move quickly and it's hard to click.
I'm using the Manjaro shipped PBP and I don't have Sensitivity controls in the system settings.
The pointer motion settings that seem to work for me (pic):
[Image: b73a414074f59ca481783c6b741dbf4b-full.png]
Cheers!
"MtnSk8" - Yeah, reducing the Pointer Motion Speed Minimum to the lowest setting appears to help. Thanks!
I suggest you update the firmware, the one that shipped from the factory was garbage, since then some hackers have managed to improve it quite a lot: https://github.com/jackhumbert/pinebook-...rd-updater
(07-26-2020, 02:34 AM)slyecho Wrote: I suggest you update the firmware, the one that shipped from the factory was garbage, since then some hackers have managed to improve it quite a lot: https://github.com/jackhumbert/pinebook-...rd-updater
would this update also apply to the units that shipped in May 2020? What are some of the issues that this firmware is addressing?
I'm not aware of what state the factory firmware has been since I got mine in January. The main bug it fixes is that the touchpad doesn't report its dimensions correctly.
You can read more about this here: https://github.com/akirakyle/pinebook-pr...README.org
(07-26-2020, 01:19 PM)slyecho Wrote: I'm not aware of what state the factory firmware has been since I got mine in January. The main bug it fixes is that the touchpad doesn't report its dimensions correctly.
Thanks. I don't think I'm experiencing any of these issues described in the new firmware update. My issue was just with sensitivity of the pointer which got resolved by just reducing the pointer motion minimum speed all the way down. Now I'm wondering if the units shipped in May 2020 (Manjaro) have a different keyboard/touchpad firmware.
  Mouse drfting when using the trackpad jcarty 1 2,731 09-15-2020, 03:21 PM
Last Post: ab1jx
  Picked up a decent bluetooth mouse bastafari 0 1,763 09-10-2020, 07:59 AM
Last Post: bastafari
  Trackpad sensitivity barn 1 2,838 08-06-2020, 01:03 PM
  Right Click touchpad sensitivity tomfowler 4 6,308 05-31-2020, 12:32 PM
Last Post: gwalker
  Manjaro Mouse cmelcher 5 6,508 04-19-2020, 07:38 AM
Last Post: cmelcher
  lol touchpad causes mouse to move all over the place when using in a car james64 0 2,164 02-05-2020, 08:16 AM
Last Post: james64
