New to PinePhone - one basic question
(My apologies in advance if I've posted this in the wrong forum. I think this is the right one, but...)
I just found out about the PinePhone and I'd love to try one and see what it's like.
My main question is "Can the PinePhone run android apps?" Is there some way to do that?
(I realize this probably isn't a straight yes or no answer to this and that it's probably been asked a thousand times. I searched the forum a bit but couldn't find a clear discussion on this, so I'm sorry if this is an oft-repeated question.)
If the answer is just plain 'no', that'll tell me something and I can go from there.
If the answer is 'yes' or 'sort of yes' or 'maybe' or 'it depends', then great- anything you can tell me along those lines would be welcome, or maybe point me to some discussion threads here that I can read through.
Thank you in advance.
(07-15-2020, 06:31 PM)Mike X Wrote: (My apologies in advance if I've posted this in the wrong forum. I think this is the right one, but...)
You're  searching for Anbox. It will allow android apps to run on the pinephone, but it's all early stages so not ready yet. Same with Libertine and running desktop linux apps. Give it some time. Need stable builds before Anbox and Libertine can be applied.
Then there's this     https://www.omgubuntu.co.uk/2020/07/glod...-allwinner
  PinePhone - boot from microSD laserpyramid 7 594 Yesterday, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 355 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 240 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,232 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,807 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 612 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,374 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 501 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,710 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,983 12-04-2023, 02:14 AM
Last Post: Peter Gamma
