Noobiest of noob question - how to go back or exit in ubports
Greetings,
This question is embarrassing, because maybe I've missed something obvious.
How does one navigate "backwards" on UBports? I'm used to the back key on Android either suspending the program or moving "back" a pane.
What would the equivalent gesture or button be on UBports to suspend the current task and get back to the desktop screen?
Thanks.
When running the first time, you should've seen a tutorial. On https://ubuntu-touch.io/nl/elegance-and-simplicity you have the same information under the fifth title "Elegant and innovative" (about the swipes).
(07-09-2020, 06:37 AM)davidbe Wrote: When running the first time, you should've seen a tutorial. On https://ubuntu-touch.io/nl/elegance-and-simplicity you have the same information under the fifth title "Elegant and innovative" (about the swipes).
Thanks, I'm on to it now. It's a short swipe to jump from one open program to the next. Long swipe brings up the full deck. That's an interesting novel method for navigation. Unlike Android, I can see an advantage in that screen space isn't taken by more on-screen buttons.
Though, is there any way to quickly bring up the home screen with the background? It isn't *that* vital to the workflow, but it is something I'd do reasonably often on Android. But now I think of it, this wasn't a feature of Windows Phone or iOS either.
Sailfish has similar gestures and is much better than (b)android.
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,936 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  online accounts in UBports Uturn 2 4,186 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 9,627 03-13-2021, 01:51 PM
Last Post: KNERD
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 3,036 11-27-2020, 07:40 PM
Last Post: piney-tim
  UBPorts Convergence MonCon 0 2,347 11-24-2020, 04:25 PM
Last Post: MonCon
  Looks like I found a mild reason why UBPorts for pinephone hasn't seen much progress. plainenough 13 17,520 11-21-2020, 06:30 PM
Last Post: Nooblife
  "No network" on new UBPorts community edition pinephone professorsnapper 6 7,881 10-19-2020, 10:27 PM
Last Post: htc_tattoo
  UBPorts doesn't boot even after booting into recovery defekto 2 4,491 09-30-2020, 12:16 PM
Last Post: defekto
  Dekko on UBPorts PinePhone usable? djvinniev77 13 15,392 09-17-2020, 03:45 PM
Last Post: yurievitch
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 20,031 09-15-2020, 03:42 PM
Last Post: voidmain
