Can I use UT apps with another distro ?
Hey !
Does anyone know how I can use apps from Ubuntu Touch, like file-manager, Dekko2 with ArchLinuxArm for PinePhone ? I tried by installing clickable from AUR but I don't have much knowledge so it's not working :/
I think I could try to use this phone as a daily phone just with Mail/Calendar/File-Manager/Notes apps. UT is not usable, Bluetooth not deactivating, cellular not working, same for GPS... But Arch + Posh is smooth and everything works find, it's why I want to use some UT apps with Arch ^^
Thanks.
Unfortunately most UT apps have various UT specific UI dependencies. I think the pmOS guys are trying to get them running on other systems. But I think the biggest hurdle is that UT uses Mir instead of Wayland or X11.
if the app in question uses a web interface as the UI it should be easier to decouple it from UT. I had some luck with axolotl. For me it's currently just running as a server and I open the UI with a browser.
For mail and calendar I currently use Evolution. Not ideal, but it works with the small screen after a few tweaks. But the Geary developer is aparently working on better mobile compatibility.
Isn't UBports on the pinephone using Wayland though?
  Sms apps and signal messenger boggle 8 7,380 02-16-2024, 06:03 AM
Last Post: zetabeta
  [Video] LVGL in WebAssembly: Building NuttX Touchscreen Apps with Zig lupyuen 0 792 09-30-2023, 03:37 AM
Last Post: lupyuen
Question Proprietary apps for PinePhone/PineTab Benoit 10 13,179 10-14-2022, 12:29 AM
Last Post: groomsb31
  LinuxPhoneApps.org lists over 400 apps now - and now has a thread here linmob 0 1,228 10-11-2022, 12:17 PM
Last Post: linmob
  Web apps oliwierzgorniak 2 1,596 09-24-2022, 10:20 AM
Last Post: oliwierzgorniak
  Distro for writers, k & m, LibreOffice, PostmarketOS? Peter Gamma 14 8,715 09-11-2022, 07:22 AM
Last Post: Juergen
  Which apps can I run on this phone? poppyhodler 2 2,276 06-07-2022, 12:18 PM
Last Post: jenniferjohn12
  Pinephone: Is there a frugal distro? orbital 2 1,985 05-27-2022, 09:34 PM
Last Post: orbital
  Bluetooth low energy & ANT+ sports sensors Pinephone distro? Peter Gamma 34 49,424 12-08-2021, 04:50 AM
Last Post: thibaultmol
  Pinephone Apps Unified Dev Hub biketool 11 9,640 09-09-2021, 10:53 AM
Last Post: ragreenburg
