Kali boot issues
Hi there. I recently flashed kali linux to my emmc module and I'm having some boot issues. I booted from an SD card using debian, deleted all partitions on the emmc, downloaded the kali image and then used 'dd' to flash it to the emmc module. After I shut down, pop out the SD card and then power up, the system boots into Kali just fine from the emmc, as expected. However, if I shut my pinebook off for a day or so and then come back and turn it on, all of a sudden it won't boot. I just get a solid red (amber?) light and blank screen when I power up. I've repeated this process multiple times with the same results. Initially I can boot no problem, but then it won't after being off for a while. It almost seems like there's something wrong with the emmc module....
Any ideas?
I may have spoken too soon. It seems there's an issue with PBP not booting after updating with apt-get in Kali, which has been recently addressed in a nightly release. I'm going to experiment with other OS's but assume for now that that was my issue.
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,219 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,231 11-23-2023, 07:37 AM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,020 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,971 08-21-2023, 09:08 PM
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 660 07-13-2023, 05:21 PM
Last Post: owaspfap
  Emergency Mode Boot Hotkey? jiacovelli 20 4,433 06-02-2023, 01:32 PM
  Kali Linux for Pinebook Pro Luke 100 159,436 05-03-2023, 06:10 AM
Last Post: dachalife
  Tow Boot install help Paulie420 7 3,766 11-24-2022, 10:24 AM
Last Post: myself600
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 2,984 11-02-2022, 02:33 PM
Last Post: kebab
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 1,975 10-31-2022, 10:14 AM
