PinePhone CE and USB-C Video Out
(06-19-2020, 10:36 AM)megous Wrote:
(06-17-2020, 08:46 AM)heng Wrote: What software do I use to switch the USB state?
Not much, it's not possible to workaround this in software. ANX firmware malfunctions if CC pins don't behave as expected, and there's no way to communicate with the dock to enable alt-dp mode. There's no manual override.
this just got put up ARCH linx tho   https://www.youtube.com/watch?v=LdKNugT-mTQ
Yeah, that's a video I made, and the phone in it has the HW fix.
This suggests there's a software way to manually select PinePhone's data and power role:
https://wiki.pine64.org/index.php?title=...ONN_is_off
If so... how would one go about doing it? I'm less concerned with external display (which would be nice, but oh well) than I am with being able to connect to my desktop via USB.
(07-02-2020, 10:11 AM)Hiraghm Wrote: This suggests there's a software way to manually select PinePhone's data and power role:
https://xnux.eu/devices/feature/anx7688....pp-1-0-1-2
  PinePhone - boot from microSD laserpyramid 7 603 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 363 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 243 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,490 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,840 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 616 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,381 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 507 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,714 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,989 12-04-2023, 02:14 AM
Last Post: Peter Gamma
