Pinephone pkgsrc
Hello all,
in case anybody is interested I have successfully bootstrapped pkgsrc-current (www.pkgsrc.org) on the PostmarketOS Pinephone.
I have built some tools that seems to be missing from the official Alpine apk repository
- mingw-w64 (http://www.mingw.org/)  for both the x86_64 and i686 targets
So now you can compile natively code on the Pinephone for Winows x86_64 and i686
You can find my packages (more are on the way) on my repo @ http://45.76.81.249/pkgsrc/pinephone/
As usual you can track my progress on Twitter @ https://twitter.com/astr0baby
- I have finished a custom build of hyperion hercules - so in short time I will try to run MVS (http://wotho.ethz.ch/tk4-/) on the Pinephone; yes that is
correct - a mainframe on the Pinephone.
  PinePhone - boot from microSD laserpyramid 7 632 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 367 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 247 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,661 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,856 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 625 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,411 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 511 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,737 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,005 12-04-2023, 02:14 AM
Last Post: Peter Gamma
