06-06-2020, 12:11 AM
Are we supposed to peel off the thin plastic cover from the touchpad?
touchpad
06-06-2020, 12:31 AM
(06-06-2020, 12:11 AM)tanzim8145 Wrote: Are we supposed to peel off the thin plastic cover from the touchpad? I don't remember mine having a protective film on it, but yes, apparently there is one now and can be peeled off...
New PBP owner here too (May 2020) - yes there is a thin transparent plastic cover on the touch pad it can be peeled off. The touch pad will work with or without the plastic film - I believe you could also "skin" the touch pad, if you're in to skinning. There's also a plastic film over the camera that you can peel off too.
Finally... The touchpad works great! | dsimic | 111 | 139,925 |
03-13-2023, 09:41 PM Last Post: kellrobinson |
Keyboard/Touchpad update SH61F83 IC | zaphod80013 | 4 | 3,309 |
09-14-2022, 03:56 AM Last Post: Carl |
Sticker on touchpad | fbkr | 3 | 5,407 |
11-10-2020, 10:10 PM Last Post: pFalken |
Touchpad self generates events | jpalus | 0 | 2,024 |
10-18-2020, 11:38 AM Last Post: jpalus |
Do I need the touchpad update? | Paulie420 | 3 | 5,551 |
09-22-2020, 06:40 PM Last Post: Paulie420 |
Right Click touchpad sensitivity | tomfowler | 4 | 6,303 |
05-31-2020, 12:32 PM Last Post: gwalker |
lol touchpad causes mouse to move all over the place when using in a car | james64 | 0 | 2,162 |
02-05-2020, 08:16 AM Last Post: james64 |
Touchpad issues | drufusb | 5 | 7,772 |
11-30-2019, 02:18 AM Last Post: drufusb |
