E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release
I'm trying to resurrect my Pinebook and could use a hand. I've got a black screen and cursor (I skip the login?) so I think something is wrong with Plasma.
I'm starting the fix by trying to run updates (I'm on some 18.* release of Ubuntu under the hood) but I'm getting:
`E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release file.`
It looks like the files I need to point to are here: https://files.kde.org/neon/images/pinebo...eredition/
But when I try to edit my sources.list all I see are the two main Ubuntu ports (bionic and bionic-updates).
Does anyone know where I can find and edit the `http://pinebook.kde.org.uk bionic Release` entry?
try looking int he folder with sources.list for another sources.list file, that should be labeled as specifically kde/neon
what do you edit the pinebook.list to say?
When I add the url to my file it still says there is no release file.
you might try the repos given here in this script https://invent.kde.org/neon/neon/reposit...s.postinst
  DietPi OS for Pinebook MichaIng 3 5,605 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 63,215 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 1,048 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 820 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 4,038 04-13-2023, 01:09 PM
  Armbian 22.02 Release Announcement TRS-80 0 1,400 02-28-2022, 05:02 PM
Last Post: TRS-80
  Stock Debian on original Pinebook moonwalkers 1 3,331 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 4,026 01-04-2022, 09:22 PM
Last Post: irongarment
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,891 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,878 12-25-2020, 04:40 PM
Last Post: ford442
