[split] U-Boot with NVMe support, keyboard & display working
#41
Indeed the vertical bars are startling
I blanked 1st 16M on emmc, restored mbr,, put (only) this on SD
(because 1st 16M blank SPI & emmc,, forced to use uboot on SD, slightly safer)
The keyboard is indeed flakey, misses keystrokes, slow
And, alas, like all other uboots, cannot boot SD in usb carrier/dongle
Just does not see the storage
But then I thought, try the usb2 port
And it finds the SD/carrier, fails to boot anything
However, a gigantic plus, none of this "locked" pbp
(locked requires an extra long press without bad uboot, ie a good one or emmc disabled)
Some updates, the main important one is that the USB wonkyness has been solved. Read the PR comments to see what's up.
And can we hope that some will compile this? I can't.
@as400 maybe?
or is it hidden on the git somewhere?
I don't know if it's worth it ?
If there is only keyboard change then the kernel booting problem is still there.
Unless someone has a kernel with a patch applied. AFAIK there is no other solution to that.
You have a point,, but
I found that it was almost unusable because of keyboard,
so had no interest in experimenting
If the keyboard works, I would "poke" at it,
start learning how to set up multi-menus, check sleep, etc
Not so brave as to put on SPI, emmc/sd version please
OK - so you can grab binaries from:
https://gitlab.com/as400l/pbp-uboot-display-menu
I have not tested these binaries so be careful.
And report how it goes with new kernel versions Smile
Thanks so much,, yes will keep notes and reply,,results, this thread
(09-17-2020, 01:54 AM)as400 Wrote: I have not tested these binaries so be careful.
It booted 5.8.6-1-MANJARO-ARM from eMMC just fine & it didn't brick my system!
I feel a lot better knowing that I can select my boot devices now!
@NickL can you try booting multiple times ?
Where do you have uboot? SD or SPI ?
(09-17-2020, 10:18 AM)as400 Wrote: @NickL can you try booting multiple times ?
I've got my u-boot on SPI.
I noticed a bit of flakiness on bootup, which I've resolved by ejecting the SD card or by going via the boot menu. With the stock u-boot, I needed to eject the SD card to make things work at all, so this is an improvement.
When it fails to boot, it seems to get lost at the handoff from uBoot to Linux.
EDIT: I did find one regression. Under the stock U-Boot, sleep seems to be a no-op. With this updated U-Boot, the system is now capable of going to sleep, but it will never wake up. I disabled sleep and the problem went away.
  upgrading u-boot--what version? where to get it? bsammon 11 528 05-22-2024, 09:33 AM
  uboot wont boot to SD card after upgrade jbradley419 7 1,139 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 395 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,533 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 868 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 714 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 856 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,367 09-19-2023, 08:48 AM
Last Post: dachalife
  Dead Pinebook Pro Keyboard Keys calinb 2 1,186 09-02-2023, 12:31 PM
Last Post: calinb
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,126 08-03-2023, 03:30 PM
