Phone doesn't boot after latest kernel update
I did a apt upgrade yesterday evening (about 24h ago) and saw that the only package to update the kernel was. After the update was done I rebooted the phone and it only showed a black screen.
I was running off of EMMC but I still had an older version on my SD. So I put that in, updated it and it wouldn't boot either.
I have an unmodified Braveheart. When I try to boot the phone I see the green LED, the screen lights up black for a few seconds, it turns off, I hear the clicking from the camera and that's it. When I leave the phone running it gets pretty hot. I cannot reach it over WiFi.
Tomorrow I will try to put the latest image on the SD and see what happens then.
Actually, I can reach it via WiFi. I'll see if I can get some more information out of it.
dmesg shows the error
[   12.096839] anx7688 1-0028: boot firmware load failed (you may need to flash FW to anx7688 first)
[   12.120840] anx7688 1-0028: power disabled
[   12.120896] anx7688 1-0028: spurious status irq
Not sure if it is related, but I just did an update with
apt update && apt dist-upgrade
and the process got stuck somewhere in the middle. I restarted it, and it got stuck again.
I think I did my last upgrade this morning. I did see a kernel upgrade but have not yet re-booted. Seems I should try avoid a reboot for as long as possible!
(And also seems same issue on UBports & pmOS)
I blacklisted the anx7688 module but the screen still remains black. I will post the full dmesg output tomorrow.
This is my dmesg:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.7-pinephone (mobian@mobian) (gcc version 9.3.0 (Debian 9.3.0-15), GNU ld (GNU Binutils for Debian) 2.34.90.20200706) #5.7.0+pinephone9 SMP PREEMPT Tue Jul 21 17:26:00 CEST 2020
[    0.000000] Machine model: Pine64 PinePhone Braveheart (1.1)
[    0.000000] cma: Reserved 256 MiB at 0x00000000b0000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xafbca100-0xafbcbfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   DMA32    [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 262144 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 22 pages/cpu s51480 r8192 d30440 u90112
[    0.000000] pcpu-alloc: s51480 r8192 d30440 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: ARM erratum 843419
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: console=ttyS0,115200 no_console_suspend panic=10 consoleblank=0 loglevel=7 root=/dev/mmcblk2p1 rw splash plymouth.ignore-serial-consoles vt.global_cursor_default=0
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x7bfff000-0x7ffff000] (64MB)
[    0.000000] Memory: 1698272K/2097152K available (10110K kernel code, 626K rwdata, 3936K rodata, 1664K init, 378K bss, 136736K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x308/0x4cc with crng_init=0
[    0.000000] arch_timer: Enabling global workaround for Allwinner erratum UNKNOWN1
[    0.000000] arch_timer: CPU0: Trapping CNTVCT access
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000476] Console: colour dummy device 80x25
[    0.000582] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000596] pid_max: default: 32768 minimum: 301
[    0.000710] LSM: Security Framework initializing
[    0.000821] AppArmor: AppArmor initialized
[    0.000891] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.000914] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.002933] rcu: Hierarchical SRCU implementation.
[    0.003729] smp: Bringing up secondary CPUs ...
[    0.005782] Detected VIPT I-cache on CPU1
[    0.005837] arch_timer: CPU1: Trapping CNTVCT access
[    0.005850] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.007015] Detected VIPT I-cache on CPU2
[    0.007044] arch_timer: CPU2: Trapping CNTVCT access
[    0.007053] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.008163] Detected VIPT I-cache on CPU3
[    0.008189] arch_timer: CPU3: Trapping CNTVCT access
[    0.008199] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.008305] smp: Brought up 1 node, 4 CPUs
[    0.008335] SMP: Total of 4 processors activated.
[    0.008345] CPU features: detected: 32-bit EL0 Support
[    0.008354] CPU features: detected: CRC32 instructions
[    0.022990] CPU: All CPU(s) started at EL2
[    0.023026] alternatives: patching kernel code
[    0.024903] devtmpfs: initialized
[    0.035284] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.035311] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.044986] pinctrl core: initialized pinctrl subsystem
[    0.046349] thermal_sys: Registered thermal governor 'fair_share'
[    0.046355] thermal_sys: Registered thermal governor 'bang_bang'
[    0.046370] thermal_sys: Registered thermal governor 'step_wise'
[    0.046377] thermal_sys: Registered thermal governor 'user_space'
[    0.047890] NET: Registered protocol family 16
[    0.050127] DMA: preallocated 256 KiB pool for atomic allocations
[    0.050157] audit: initializing netlink subsys (disabled)
[    0.050423] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[    0.051729] cpuidle: using governor menu
[    0.052016] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.052146] ASID allocator initialised with 65536 entries
[    0.052391] Serial: AMBA PL011 UART driver
[    0.083508] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.083526] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.083536] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.083545] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.086868] cryptd: max_cpu_qlen set to 1000
[    0.096415] iommu: Default domain type: Translated
[    0.096918] SCSI subsystem initialized
[    0.097178] libata version 3.00 loaded.
[    0.097596] usbcore: registered new interface driver usbfs
[    0.097667] usbcore: registered new interface driver hub
[    0.097768] usbcore: registered new device driver usb
[    0.098405] mc: Linux media interface: v0.10
[    0.098457] videodev: Linux video capture interface: v2.00
[    0.098516] pps_core: LinuxPPS API ver. 1 registered
[    0.098525] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.098558] PTP clock support registered
[    0.098916] EDAC MC: Ver: 3.0.0
[    0.101555] clocksource: Switched to clocksource arch_sys_counter
[    0.101879] VFS: Disk quotas dquot_6.6.0
[    0.101960] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.102889] AppArmor: AppArmor Filesystem Enabled
[    0.112963] NET: Registered protocol family 2
[    0.113715] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.113764] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.113927] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.114283] TCP: Hash tables configured (established 16384 bind 16384)
[    0.114451] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.114515] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.114752] NET: Registered protocol family 1
[    0.115370] RPC: Registered named UNIX socket transport module.
[    0.115379] RPC: Registered udp transport module.
[    0.115386] RPC: Registered tcp transport module.
[    0.115393] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.115663] Unpacking initramfs...
[    0.933933] Freeing initrd memory: 13492K
[    0.935106] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.935850] kvm [1]: IPA Size Limit: 40bits
[    0.936531] kvm [1]: vgic interrupt IRQ1
[    0.936706] kvm [1]: Hyp mode initialized successfully
[    1.228777] Initialise system trusted keyrings
[    1.228995] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.239924] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.241179] NFS: Registering the id_resolver key type
[    1.241219] Key type id_resolver registered
[    1.241227] Key type id_legacy registered
[    1.241246] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.241494] 9p: Installing v9fs 9p2000 file system support
[    1.272659] Key type asymmetric registered
[    1.272678] Asymmetric key parser 'x509' registered
[    1.272777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.272788] io scheduler mq-deadline registered
[    1.272798] io scheduler kyber registered
[    1.273948] sun50i-de2-bus 1000000.bus: Error couldn't map SRAM to device
[    1.275418] sun4i-usb-phy 1c19400.phy: failed to get clock usb0_phy
[    1.276128] sun6i-mipi-dphy 1ca1000.d-phy: Couldn't create the DPHY encoder regmap
[    1.280956] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    1.283148] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
[    1.300394] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.308236] sun6i-mipi-dsi 1ca0000.dsi: Couldn't get VCC-DSI supply
[    1.314200] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[    1.314285] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[    1.314361] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[    1.314424] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[    1.314914] lima 1c40000.gpu: bus rate = 200000000
[    1.314926] lima 1c40000.gpu: mod rate = 500000000
[    1.315389] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 0
[    1.328197] loop: module loaded
[    1.332083] libphy: Fixed MDIO Bus: probed
[    1.332100] tun: Universal TUN/TAP device driver, 1.6
[    1.334911] VFIO - User Level meta-driver version: 0.3
[    1.336648] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.336662] ehci-platform: EHCI generic platform driver
[    1.337001] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.337031] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.337183] ehci-platform 1c1a000.usb: irq 20, io mem 0x01c1a000
[    1.349585] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.350534] hub 1-0:1.0: USB hub found
[    1.350579] hub 1-0:1.0: 1 port detected
[    1.351617] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.351667] ohci-platform: OHCI generic platform driver
[    1.351976] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.352003] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.352166] ohci-platform 1c1a400.usb: irq 21, io mem 0x01c1a400
[    1.414458] hub 2-0:1.0: USB hub found
[    1.414505] hub 2-0:1.0: 1 port detected
[    1.416197] usbcore: registered new interface driver usb-storage
[    1.418613] sun6i-rtc 1f00000.rtc: registered as rtc0
[    1.418670] sun6i-rtc 1f00000.rtc: setting system clock to 2020-07-23T06:25:13 UTC (1595485513)
[    1.418681] sun6i-rtc 1f00000.rtc: RTC enabled
[    1.418920] i2c /dev entries driver
[    1.423103] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[    1.424061] sdhci: Secure Digital Host Controller Interface driver
[    1.424073] sdhci: Copyright(c) Pierre Ossman
[    1.424279] Synopsys Designware Multimedia Card Interface Driver
[    1.425812] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.427423] ledtrig-cpu: registered to indicate activity on CPUs
[    1.428125] hid: raw HID events driver (C) Jiri Kosina
[    1.429168] usbcore: registered new interface driver usbhid
[    1.429181] usbhid: USB HID core driver
[    1.429674] ashmem: initialized
[    1.434829] NET: Registered protocol family 17
[    1.435091] 9pnet: Installing 9P2000 support
[    1.435133] Key type dns_resolver registered
[    1.435639] registered taskstats version 1
[    1.435651] Loading compiled-in X.509 certificates
[    1.435792] AppArmor: AppArmor sha1 policy hashing enabled
[    1.459621] sunxi-rsb 1f03400.rsb: RSB running at 4000000 Hz
[    1.460130] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
[    1.462705] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input1
[    1.465640] axp20x-adc axp813-adc: DMA mask not set
[    1.466926] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[    1.474187] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[    1.476245] dcdc1: supplied by regulator-dummy
[    1.476807] dcdc2: supplied by regulator-dummy
[    1.477252] dcdc4: supplied by regulator-dummy
[    1.477342] random: fast init done
[    1.477733] dcdc5: supplied by regulator-dummy
[    1.478205] dcdc6: supplied by regulator-dummy
[    1.478642] dc1sw: supplied by regulator-dummy
[    1.479017] aldo1: supplied by regulator-dummy
[    1.479139] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[    1.479546] aldo2: supplied by regulator-dummy
[    1.479965] aldo3: supplied by regulator-dummy
[    1.480417] dldo1: supplied by regulator-dummy
[    1.480892] dldo2: supplied by regulator-dummy
[    1.480987] vcc-dsi-io: Bringing 2900000uV into 1800000-1800000uV
[    1.481409] dldo3: supplied by regulator-dummy
[    1.481509] avdd-csi: Bringing 2900000uV into 2800000-2800000uV
[    1.482130] dldo4: supplied by regulator-dummy
[    1.482713] eldo1: supplied by regulator-dummy
[    1.483179] eldo2: supplied by regulator-dummy
[    1.483630] eldo3: supplied by regulator-dummy
[    1.483755] dvdd-csi: Bringing 700000uV into 1800000-1800000uV
[    1.484179] fldo1: supplied by regulator-dummy
[    1.484647] fldo2: supplied by regulator-dummy
[    1.485130] rtc-ldo: supplied by regulator-dummy
[    1.485635] ldo-io0: supplied by regulator-dummy
[    1.486130] ldo-io1: supplied by regulator-dummy
[    1.486232] vcc-1v8-typec: Bringing 3300000uV into 1800000-1800000uV
[    1.486551] axp20x-regulator axp20x-regulator: drivevbus has vin
[    1.487163] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
[    1.494105] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    1.510857] printk: console [ttyS0] disabled
[    1.510938] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 32, base_baud = 1500000) is a 16550A
[    2.815509] printk: console [ttyS0] enabled
[    2.821381] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 33, base_baud = 1500000) is a 16550A
[    2.830326] serial serial0: tty port ttyS1 registered
[    2.836483] 1c28c00.serial: ttyS2 at MMIO 0x1c28c00 (irq = 34, base_baud = 1500000) is a 16550A
[    2.846823] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] *ERROR* mipi_dsi_attach failed (-517). Is host ready?
[    2.889909] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[    2.901644] sun4i-drm display-engine: bound 1200000.mixer (ops sun8i_mixer_ops)
[    2.909581] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    2.917430] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[    2.925802] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops sun4i_tcon_ops)
[    2.933852] sun4i-drm display-engine: bound 1ca0000.dsi (ops sun6i_dsi_ops)
[    2.942174] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    2.952384] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.960483] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
[    2.967892] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.975150] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 1
[    3.769987] Console: switching to colour frame buffer device 128x48
[    3.792886] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[    3.801032] ehci-platform 1c1b000.usb: EHCI Host Controller
[    3.806654] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    3.814555] ehci-platform 1c1b000.usb: irq 22, io mem 0x01c1b000
[    3.833570] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    3.840537] hub 3-0:1.0: USB hub found
[    3.844351] hub 3-0:1.0: 1 port detected
[    3.849525] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    3.856196] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
[    3.864113] ohci-platform 1c1b400.usb: irq 23, io mem 0x01c1b400
[    3.934365] hub 4-0:1.0: USB hub found
[    3.938167] hub 4-0:1.0: 1 port detected
[    3.943682] input: 1c21800.lradc as /devices/platform/soc/1c21800.lradc/input/input2
[    3.952857] input: gpio-vibrator as /devices/platform/vibrator/input/input3
[    4.063072] Goodix-TS 1-005d: ID 917S, version: 0200
[    4.069505] Goodix-TS 1-005d: Direct firmware load for goodix_917S_cfg.bin failed with error -2
[    4.087044] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    4.101158] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-005d/input/input4
[    4.124022] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    4.160113] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    4.191995] mmc1: new high speed SDIO card at address 0001
[    4.198002] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.214391] scpi_protocol scpi: SCP Protocol 1.2 Firmware 0.1.9000 version
[    4.224013] drivevbus: supplied by vcc5v0
[    4.228188] usb0-vbus: supplied by drivevbus
[    4.322197] mmc2: new DDR MMC card at address 0001
[    4.328182] mmcblk2: mmc2:0001  14.7 GiB
[    4.332775] mmcblk2boot0: mmc2:0001  partition 1 4.00 MiB
[    4.341439] mmcblk2boot1: mmc2:0001  partition 2 4.00 MiB
[    4.352952]  mmcblk2: p1
[    4.757020] sun6i-mipi-dsi 1ca0000.dsi: Attached device xbd599
[    4.762934] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] 720x1440@55 24bpp dsi 4dl - ready
[    4.773716] input: gpio-keys as /devices/platform/gpio-keys/input/input5
[    4.784528] Freeing unused kernel memory: 1664K
[    4.825672] Run /init as init process
[    4.829338]   with arguments:
[    4.829344]     /init
[    4.829351]     splash
[    4.829357]   with environment:
[    4.829364]     HOME=/
[    4.829370]     TERM=linux
[    5.274352] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[    5.322419] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
[    5.332507] phy id_det change to device
[    5.334006] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[    5.342254] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
[    5.350896] hub 5-0:1.0: USB hub found
[    5.354788] hub 5-0:1.0: 1 port detected
[    6.567338] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.252995] NET: Registered protocol family 10
[    7.258557] Segment Routing with IPv6
[    7.289686] systemd[1]: systemd 245.6-2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    7.318803] systemd[1]: Detected architecture arm64.
[    7.356410] systemd[1]: Set hostname to <pinephone>.
[    8.042347] random: systemd: uninitialized urandom read (16 bytes read)
[    8.049252] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    8.061871] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    8.073410] systemd[1]: Created slice system-modprobe.slice.
[    8.079885] random: systemd: uninitialized urandom read (16 bytes read)
[    8.087861] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.094617] random: systemd: uninitialized urandom read (16 bytes read)
[    8.102678] systemd[1]: Created slice User and Session Slice.
[    8.109222] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.118086] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.128198] systemd[1]: Reached target User and Group Name Lookups.
[    8.134865] systemd[1]: Reached target Remote File Systems.
[    8.140813] systemd[1]: Reached target Slices.
[    8.145638] systemd[1]: Reached target Swap.
[    8.150225] systemd[1]: Reached target System Time Set.
[    8.156419] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.163928] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.171676] systemd[1]: Listening on Journal Audit Socket.
[    8.178151] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.185210] systemd[1]: Listening on Journal Socket.
[    8.191338] systemd[1]: Listening on udev Control Socket.
[    8.197683] systemd[1]: Listening on udev Kernel Socket.
[    8.208551] systemd[1]: Mounting Huge Pages File System...
[    8.219675] systemd[1]: Mounting POSIX Message Queue File System...
[    8.231815] systemd[1]: Mounting Kernel Debug File System...
[    8.238925] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    8.252868] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    8.262266] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    8.278738] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    8.288104] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.303625] systemd[1]: Starting Journal Service...
[    8.315877] systemd[1]: Starting Load Kernel Modules...
[    8.328231] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.342095] systemd[1]: Starting udev Coldplug all Devices...
[    8.356578] systemd[1]: Mounted Huge Pages File System.
[    8.364465] systemd[1]: Mounted POSIX Message Queue File System.
[    8.373303] systemd[1]: Mounted Kernel Debug File System.
[    8.380633] EXT4-fs (mmcblk2p1): re-mounted. Opts: (null)
[    8.389717] random: crng init done
[    8.393142] random: 7 urandom warning(s) missed due to ratelimiting
[    8.393145] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    8.412364] systemd[1]: Finished Load Kernel Modules.
[    8.422365] systemd[1]: Finished Remount Root and Kernel File Systems.
[    8.432034] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    8.445619] systemd[1]: Mounting Kernel Configuration File System...
[    8.462051] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    8.471405] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    8.486072] systemd[1]: Starting Load/Save Random Seed...
[    8.498550] systemd[1]: Starting Apply Kernel Variables...
[    8.511396] systemd[1]: Starting Create System Users...
[    8.525890] systemd[1]: Mounted Kernel Configuration File System.
[    8.684515] systemd[1]: Finished Apply Kernel Variables.
[    8.751654] systemd[1]: Finished Load/Save Random Seed.
[    8.765298] systemd[1]: Finished udev Coldplug all Devices.
[    8.781514] systemd[1]: Finished Create System Users.
[    8.794109] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.857121] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.865690] systemd[1]: Reached target Local File Systems (Pre).
[    8.872357] systemd[1]: Reached target Local File Systems.
[    8.884145] systemd[1]: Starting Load AppArmor profiles...
[    8.895511] systemd[1]: Started Jitterentropy Gatherer Daemon.
[    8.910858] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    8.918999] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    8.934193] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    8.950404] systemd[1]: Starting udev Kernel Device Manager...
[    8.960321] systemd[1]: Received SIGRTMIN+20 from PID 1405 (plymouthd).
[    8.974634] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.115681] audit: type=1400 audit(1595485521.192:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=1489 comm="apparmor_parser"
[    9.138701] audit: type=1400 audit(1595485521.192:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1490 comm="apparmor_parser"
[    9.154567] audit: type=1400 audit(1595485521.192:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1491 comm="apparmor_parser"
[    9.169805] audit: type=1400 audit(1595485521.192:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1491 comm="apparmor_parser"
[    9.186182] audit: type=1400 audit(1595485521.192:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1491 comm="apparmor_parser"
[    9.201789] audit: type=1400 audit(1595485521.216:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="postgresql_akonadi" pid=1495 comm="apparmor_parser"
[    9.220184] audit: type=1400 audit(1595485521.232:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=1496 comm="apparmor_parser"
[    9.236270] audit: type=1400 audit(1595485521.264:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1494 comm="apparmor_parser"
[    9.254754] audit: type=1400 audit(1595485521.280:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mysqld_akonadi" pid=1493 comm="apparmor_parser"
[    9.275174] systemd[1]: Started Journal Service.
[    9.275497] audit: type=1400 audit(1595485521.280:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1498 comm="apparmor_parser"
[    9.353285] systemd-journald[1469]: Received client request to flush runtime journal.
[   10.313277] sgm3140 led-controller: supply vin not found, using dummy regulator
[   10.320925] sgm3140 led-controller: flash-max-timeout-us property missing
[   10.697205] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[   10.719636] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[   10.755418] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.810907] sun6i-csi 1cb0000.csi: creating gc2145 4-003c:0 -> sun6i-csi:0 link
[   10.824380] sun6i-csi 1cb0000.csi: creating ov5640 4-004c:0 -> sun6i-csi:0 link
[   10.832994] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.895748] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[   10.912546] bt-sco bt-sco-codec: ASoC: sink widget Capture overwritten
[   10.915269] Bluetooth: Core ver 2.22
[   10.918254] 8723cs: module is from the staging directory, the quality is unknown, you have been warned.
[   10.921860] bt-sco bt-sco-codec: ASoC: source widget Playback overwritten
[   10.922929] NET: Registered protocol family 31
[   10.932415] simple-amplifier audio-amplifier: supply VCC not found, using dummy regulator
[   10.939020] Bluetooth: HCI device and connection manager initialized
[   10.958532] Bluetooth: HCI socket layer initialized
[   10.963621] Bluetooth: L2CAP socket layer initialized
[   10.969657] asoc-simple-card sound: sun8i-codec-aif1 <-> 1c22c00.dai mapping ok
[   10.973726] Bluetooth: SCO socket layer initialized
[   10.975554] iio iio:device3: registered magnetometer lis3mdl
[   10.977119] asoc-simple-card sound: sun8i-codec-aif2 <-> ec25 mapping ok
[   10.999259] asoc-simple-card sound: sun8i-codec-aif3 <-> bt-sco-pcm mapping ok
[   11.007606] debugfs: File 'Playback' in directory 'dapm' already present!
[   11.014465] debugfs: File 'Capture' in directory 'dapm' already present!
[   11.029919] input: PinePhone Headphone Jack as /devices/platform/sound/sound/card0/input6
[   11.040640] Bluetooth: HCI UART driver ver 2.3
[   11.073865] Bluetooth: HCI UART protocol H4 registered
[   11.086104] Bluetooth: HCI UART protocol LL registered
[   11.097150] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   11.127732] Bluetooth: HCI UART protocol Broadcom registered
[   11.342817] i2c i2c-2: Added multiplexed i2c bus 5
[   11.661753] gc2145 4-003c: [wr fe] <= 00
[   11.662279] gc2145 4-003c: bank switch: 0x00
[   11.668496] gc2145 4-003c: [rd f0] => 21 45
[   11.668511] gc2145 4-003c: device id: 0x2145
[   11.677608] gc2145 4-003c: [wr fe] <= f0
[   11.680409] gc2145 4-003c: [wr fc] <= 06
[   11.680857] gc2145 4-003c: [wr f7] <= 1d
[   11.681482] gc2145 4-003c: [wr f8] <= 84
[   11.682019] gc2145 4-003c: [wr fa] <= 00
[   11.682456] gc2145 4-003c: [wr f9] <= fe
[   11.682881] gc2145 4-003c: [wr f2] <= 00
[   11.683565] gc2145 4-003c: [wr 19] <= 0c
[   11.685319] gc2145 4-003c: [wr 20] <= 01
[   11.686015] gc2145 4-003c: [wr 80] <= 0b
[   11.686587] gc2145 4-003c: [wr 86] <= 00
[   11.687597] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[   11.698199] gc2145 4-003c: Failed to read firmware gc2145-init.bin, continuing anyway...
[   11.706539] gc2145 4-003c: [wr fd] <= 00
[   11.707011] gc2145 4-003c: [wr 18] <= 0a
[   11.707442] gc2145 4-003c: [wr 09] <= 00 00
[   11.708964] gc2145 4-003c: [wr 0b] <= 00 00
[   11.711228] gc2145 4-003c: [wr 0d] <= 04 d0
[   11.712153] gc2145 4-003c: [wr 0f] <= 06 50
[   11.712757] gc2145 4-003c: [wr 05] <= 01 f1
[   11.713330] gc2145 4-003c: [wr 07] <= 00 08
[   11.714743] gc2145 4-003c: [wr 11] <= 00 1e
[   11.715352] gc2145 4-003c: [wr 13] <= 02
[   11.715779] gc2145 4-003c: [wr 14] <= 02
[   11.716222] gc2145 4-003c: [wr f7] <= 11
[   11.731560] gc2145 4-003c: [wr f8] <= 84
[   11.732369] gc2145 4-003c: [wr fa] <= 10
[   11.734252] gc2145 4-003c: [rd 82] => 00
[   11.734269] gc2145 4-003c: [wr 82] <= 00
[   11.734926] gc2145 4-003c: [wr b3] <= 40
[   11.735393] gc2145 4-003c: [wr b4] <= 40
[   11.735831] gc2145 4-003c: [wr b5] <= 40
[   11.736511] gc2145 4-003c: [wr fe] <= 01
[   11.737110] gc2145 4-003c: bank switch: 0x01
[   11.742149] gc2145 4-003c: [wr ec] <= 04
[   11.742644] gc2145 4-003c: [wr ed] <= 04
[   11.743071] gc2145 4-003c: [wr ee] <= c0
[   11.743713] gc2145 4-003c: [wr ef] <= 8e
[   11.744340] gc2145 4-003c: [wr fe] <= 00
[   11.744770] gc2145 4-003c: bank switch: 0x00
[   11.749959] gc2145 4-003c: [rd 82] => 00
[   11.749973] gc2145 4-003c: [wr 82] <= 02
[   11.750404] gc2145 4-003c: [wr b6] <= 00
[   11.750830] gc2145 4-003c: [wr 03] <= 04 b0
[   11.751584] gc2145 4-003c: [wr b1] <= 20
[   11.752041] gc2145 4-003c: [wr b2] <= e0
[   11.752599] gc2145 4-003c: [wr fe] <= 01
[   11.753083] gc2145 4-003c: bank switch: 0x01
[   11.757706] gc2145 4-003c: [wr 01] <= 04
[   11.758166] gc2145 4-003c: [wr 02] <= c0
[   11.758595] gc2145 4-003c: [wr 03] <= 04
[   11.759223] gc2145 4-003c: [wr 04] <= 8e
[   11.759899] gc2145 4-003c: [wr 05] <= 08
[   11.760631] gc2145 4-003c: [wr 06] <= b8
[   11.761515] gc2145 4-003c: [wr 07] <= 08
[   11.765784] gc2145 4-003c: [wr 08] <= 86
[   11.766252] gc2145 4-003c: [wr fe] <= 00
[   11.766722] gc2145 4-003c: bank switch: 0x00
[   11.771319] gc2145 4-003c: [wr b6] <= 01
[   11.771788] gc2145 4-003c: [wr fe] <= 01
[   11.772906] gc2145 4-003c: bank switch: 0x01
[   11.777540] gc2145 4-003c: [wr 27] <= 01 36
[   11.778186] gc2145 4-003c: [wr 35] <= 50
[   11.778866] gc2145 4-003c: [wr 29] <= 02 6c
[   11.779590] gc2145 4-003c: [wr 36] <= 50
[   11.780047] gc2145 4-003c: [wr 2b] <= 03 a2
[   11.780627] gc2145 4-003c: [wr 37] <= 50
[   11.781050] gc2145 4-003c: [wr 2d] <= 04 d8
[   11.781952] gc2145 4-003c: [wr 38] <= 50
[   11.782414] gc2145 4-003c: [wr 2f] <= 06 0e
[   11.783838] gc2145 4-003c: [wr 39] <= 50
[   11.784273] gc2145 4-003c: [wr 31] <= 07 44
[   11.799438] gc2145 4-003c: [wr 3a] <= 50
[   11.799875] gc2145 4-003c: [wr 33] <= 08 7a
[   11.800475] gc2145 4-003c: [wr 3b] <= 50
[   11.800905] gc2145 4-003c: [wr 1f] <= 50
[   11.801357] gc2145 4-003c: [wr 20] <= e0
[   11.802237] gc2145 4-003c: [wr fe] <= 00
[   11.802674] gc2145 4-003c: bank switch: 0x00
[   11.809313] gc2145 4-003c: [wr 84] <= 00
[   11.810489] gc2145 4-003c: [rd 80] => 0b
[   11.810601] gc2145 4-003c: [wr 80] <= 4b
[   11.811658] gc2145 4-003c: [rd 80] => 0b
[   11.811674] gc2145 4-003c: [wr 80] <= 0b
[   11.812965] gc2145 4-003c: [wr 24] <= ff
[   11.814644] gc2145 4-003c: [wr b6] <= 01
[   11.815091] gc2145 4-003c: [wr fe] <= 01
[   11.815616] gc2145 4-003c: bank switch: 0x01
[   11.820115] gc2145 4-003c: [wr 13] <= 7b
[   11.825500] gc2145 4-003c: [wr fe] <= 00
[   11.826049] gc2145 4-003c: bank switch: 0x00
[   11.831246] gc2145 4-003c: [rd 17] => 00
[   11.831278] gc2145 4-003c: [wr 17] <= 00
[   11.832284] gc2145 4-003c: [rd 17] => 00
[   11.832296] gc2145 4-003c: [wr 17] <= 00
[   11.832723] gc2145 4-003c: [wr 8c] <= 00
[   11.833185] gc2145 4-003c: [wr 8d] <= 01
[   11.846696] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8703
[   11.859637] Bluetooth: hci0: RTL: chip_type status=0 type=5
[   11.869307] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   11.875474] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723cs_xx_fw.bin
[   11.912300] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723cs_xx_config-pinebook.bin
[   11.953865] Bluetooth: hci0: RTL: cfg_sz 63, total sz 19427
[   12.040380] using random self ethernet address
[   12.045090] using random host ethernet address
[   12.050473] using host ethernet address: fe:ed:de:ad:be:ef
[   12.050523] using random self ethernet address
[   12.061447] gc2145 4-003c: [rd f0] => 21 45
[   12.061462] gc2145 4-003c: device id: 0x2145
[   12.066915] gc2145 4-003c: [wr fe] <= f0
[   12.067370] gc2145 4-003c: [wr fc] <= 06
[   12.067787] gc2145 4-003c: [wr f7] <= 1d
[   12.068199] gc2145 4-003c: [wr f8] <= 84
[   12.068613] gc2145 4-003c: [wr fa] <= 00
[   12.069047] gc2145 4-003c: [wr f9] <= fe
[   12.069464] gc2145 4-003c: [wr f2] <= 00
[   12.070006] gc2145 4-003c: [wr 19] <= 0c
[   12.070433] gc2145 4-003c: [wr 20] <= 01
[   12.070855] gc2145 4-003c: [wr 80] <= 0b
[   12.071274] gc2145 4-003c: [wr 86] <= 00
[   12.071759] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[   12.079754] using random host ethernet address
[   12.084475] gc2145 4-003c: Failed to read firmware gc2145-init.bin, continuing anyway...
[   12.086647] using host ethernet address: fe:ed:de:ad:be:ef
[   12.087446] usb0: HOST MAC fe:ed:de:ad:be:ef
[   12.105666] gc2145 4-003c: [wr fd] <= 00
[   12.106408] gc2145 4-003c: [wr 18] <= 0a
[   12.106875] gc2145 4-003c: [wr 09] <= 00 00
[   12.107465] gc2145 4-003c: [wr 0b] <= 00 00
[   12.108093] gc2145 4-003c: [wr 0d] <= 04 d0
[   12.108710] gc2145 4-003c: [wr 0f] <= 06 50
[   12.109298] gc2145 4-003c: [wr 05] <= 01 f1
[   12.113065] gc2145 4-003c: [wr 07] <= 00 08
[   12.113767] gc2145 4-003c: [wr 11] <= 00 1e
[   12.114695] gc2145 4-003c: [wr 13] <= 02
[   12.115655] gc2145 4-003c: [wr 14] <= 02
[   12.116515] gc2145 4-003c: [wr f7] <= 11
[   12.118616] gc2145 4-003c: [wr f8] <= 84
[   12.119064] gc2145 4-003c: [wr fa] <= 10
[   12.120372] gc2145 4-003c: [rd 82] => 00
[   12.120392] gc2145 4-003c: [wr 82] <= 00
[   12.120847] gc2145 4-003c: [wr b3] <= 40
[   12.123853] gc2145 4-003c: [wr b4] <= 40
[   12.124314] gc2145 4-003c: [wr b5] <= 40
[   12.124771] gc2145 4-003c: [wr fe] <= 01
[   12.125231] gc2145 4-003c: bank switch: 0x01
[   12.132173] gc2145 4-003c: [wr ec] <= 04
[   12.132878] gc2145 4-003c: [wr ed] <= 04
[   12.135145] gc2145 4-003c: [wr ee] <= c0
[   12.135642] gc2145 4-003c: [wr ef] <= 8e
[   12.139575] gc2145 4-003c: [wr fe] <= 00
[   12.140443] gc2145 4-003c: bank switch: 0x00
[   12.148993] gc2145 4-003c: [rd 82] => 00
[   12.149008] gc2145 4-003c: [wr 82] <= 02
[   12.149448] gc2145 4-003c: [wr b6] <= 00
[   12.149956] gc2145 4-003c: [wr 03] <= 04 b0
[   12.155017] usb0: MAC ae:b2:4a:45:83:db
[   12.161050] gc2145 4-003c: [wr b1] <= 20
[   12.161802] gc2145 4-003c: [wr b2] <= e0
[   12.162258] gc2145 4-003c: [wr fe] <= 01
[   12.164007] gc2145 4-003c: bank switch: 0x01
[   12.169370] gc2145 4-003c: [wr 01] <= 04
[   12.170159] gc2145 4-003c: [wr 02] <= c0
[   12.170628] gc2145 4-003c: [wr 03] <= 04
[   12.179475] gc2145 4-003c: [wr 04] <= 8e
[   12.179957] gc2145 4-003c: [wr 05] <= 08
[   12.180426] gc2145 4-003c: [wr 06] <= b8
[   12.181022] gc2145 4-003c: [wr 07] <= 08
[   12.181461] gc2145 4-003c: [wr 08] <= 86
[   12.182010] gc2145 4-003c: [wr fe] <= 00
[   12.182463] gc2145 4-003c: bank switch: 0x00
[   12.186879] gc2145 4-003c: [wr b6] <= 01
[   12.187489] gc2145 4-003c: [wr fe] <= 01
[   12.187955] gc2145 4-003c: bank switch: 0x01
[   12.192398] gc2145 4-003c: [wr 27] <= 01 36
[   12.193026] gc2145 4-003c: [wr 35] <= 50
[   12.193499] gc2145 4-003c: [wr 29] <= 02 6c
[   12.194518] gc2145 4-003c: [wr 36] <= 50
[   12.195100] gc2145 4-003c: [wr 2b] <= 03 a2
[   12.195697] gc2145 4-003c: [wr 37] <= 50
[   12.196275] gc2145 4-003c: [wr 2d] <= 04 d8
[   12.197045] gc2145 4-003c: [wr 38] <= 50
[   12.197499] gc2145 4-003c: [wr 2f] <= 06 0e
[   12.198206] gc2145 4-003c: [wr 39] <= 50
[   12.198721] gc2145 4-003c: [wr 31] <= 07 44
[   12.199615] gc2145 4-003c: [wr 3a] <= 50
[   12.200068] gc2145 4-003c: [wr 33] <= 08 7a
[   12.200643] gc2145 4-003c: [wr 3b] <= 50
[   12.201082] gc2145 4-003c: [wr 1f] <= 50
[   12.201883] gc2145 4-003c: [wr 20] <= e0
[   12.202588] gc2145 4-003c: [wr fe] <= 00
[   12.203223] gc2145 4-003c: bank switch: 0x00
[   12.210632] gc2145 4-003c: [wr 84] <= 00
[   12.211727] gc2145 4-003c: [rd 80] => 0b
[   12.211754] gc2145 4-003c: [wr 80] <= 4b
[   12.213258] gc2145 4-003c: [rd 80] => 0b
[   12.213280] gc2145 4-003c: [wr 80] <= 0b
[   12.213797] gc2145 4-003c: [wr 24] <= ff
[   12.214449] gc2145 4-003c: [wr b6] <= 01
[   12.215195] gc2145 4-003c: [wr fe] <= 01
[   12.215680] gc2145 4-003c: bank switch: 0x01
[   12.220134] gc2145 4-003c: [wr 13] <= 7b
[   12.220618] gc2145 4-003c: [wr fe] <= 00
[   12.221075] gc2145 4-003c: bank switch: 0x00
[   12.226478] gc2145 4-003c: [rd 17] => 00
[   12.226505] gc2145 4-003c: [wr 17] <= 00
[   12.227521] gc2145 4-003c: [rd 17] => 00
[   12.227532] gc2145 4-003c: [wr 17] <= 00
[   12.228065] gc2145 4-003c: [wr 8c] <= 00
[   12.228616] gc2145 4-003c: [wr 8d] <= 01
[   12.239757] Mass Storage Function, version: 2009/09/11
[   12.244995] LUN: removable file: (no medium)
[   12.257945] LUN: removable read only file: /dev/mmcblk2
[   12.281642] Number of LUNs=1
[   12.297816] g_multi gadget: Multifunction Composite Gadget
[   12.325619] g_multi gadget: userspace failed to provide iSerialNumber
[   12.349693] g_multi gadget: g_multi ready
[   12.383715] Bluetooth: hci0: RTL: fw version 0xaa5ca4dc
[   12.481633] Adding 290664k swap on 1.  Priority:-2 extents:5 across:1806184k SS
[   12.706999] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   12.723834] Bluetooth: BNEP filters: protocol multicast
[   12.744450] Bluetooth: BNEP socket layer initialized
[   13.165639] Adding 460144k swap on 4.  Priority:-3 extents:972 across:14983604k SS
[   13.533565] Adding 338540k swap on 2.  Priority:-4 extents:122 across:15269576k SS
[   16.460758] Bluetooth: RFCOMM TTY layer initialized
[   16.465964] Bluetooth: RFCOMM socket layer initialized
[   16.471475] Bluetooth: RFCOMM ver 1.11
[   18.637776] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   19.608653] fuse: init (API version 7.31)
[   25.478455] rfkill: input handler disabled
[   27.088136] usb 3-1: new high-speed USB device number 2 using ehci-platform
[   27.471594] usbcore: registered new interface driver option
[   27.482688] usbcore: registered new interface driver cdc_wdm
[   27.519485] qmi_wwan 3-1:1.4: cdc-wdm0: USB WDM device
[   27.551536] usbserial: USB Serial support registered for GSM modem (1-port)
[   27.577892] qmi_wwan 3-1:1.4 wwan0: register 'qmi_wwan' at usb-1c1b000.usb-1, WWAN/QMI device, d6:45:73:7c:dc:ad
[   27.593577] usbcore: registered new interface driver qmi_wwan
[   27.599685] option 3-1:1.0: GSM modem (1-port) converter detected
[   27.625893] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
[   27.647504] option 3-1:1.1: GSM modem (1-port) converter detected
[   27.665810] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
[   27.677998] option 3-1:1.2: GSM modem (1-port) converter detected
[   27.685693] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
[   27.697029] option 3-1:1.3: GSM modem (1-port) converter detected
[   27.704984] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
[   36.778696] anx-vdd1v0: disabling
[   36.782189] usb0-vbus: disabling
[   36.785530] vcc5v0: disabling
[   36.788603] vconn5v0: disabling
This here looks suspicious:
That is OK - mine (from a boot that worked) is
[    2.809845] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] *ERROR* mipi_dsi_attach failed (-517). Is host ready?
[    2.852968] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[    2.864702] sun4i-drm display-engine: bound 1200000.mixer (ops sun8i_mixer_ops)
[    2.872639] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    2.880491] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[    2.888804] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops sun4i_tcon_ops)
[    2.896845] sun4i-drm display-engine: bound 1ca0000.dsi (ops sun6i_dsi_ops)
[    2.905241] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    2.915476] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.923599] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
However from journalctl --list-boots it seems I did indeed reboot yesterday morning after the kernel upgrade - my system has been running since 08:09 BST on 22-07-2020.
I wonder if this is some regression on the proximity sensor/brightness? But I am now very puzzled why you are afflicted and I seem to have dodged the bullet!?
I had to reboot my phone earlier (grief swapping from WiFi to 4G for data) and it went just fine. Are you still struggling?
Yeah, I couldn't find the time yet to see what happens when I try to boot a recent image.
I also had this issue with the blank screen, the phosh.service unit was failing to start according to the logs, so I did the only thing I could think of after reading some troubleshooting:
dpkg-reconfigure linux-image-5.7-pinephone
rebooted and that resolved it!
The thing is that I can't even see the splash image. So it doesn't have anything to do with phosh. I tried reconfiguring the package, but it didn't work. Does someone still have linux-image-5.7-pinephone_5.7.0+pinephone8.deb in their /var/cache/apt/archives/ folder?
It definitely seems to be related to the kernel. When I install the latest stable release with the pinephone8 kernel it works. As soon as I update the kernel to pinephone9 it doesn't work. The latest nightly doesn't work either.
I reported it here: https://gitlab.com/mobian1/devices/pinep.../issues/10
Still had the deb for the pinephone6 version. So at least I can now use my phone again.
  The program doesn`t detect the camera blag0rag 2 509 02-15-2024, 08:03 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,384 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 1,155 09-29-2023, 11:29 PM
  No volume control after latest updates Zebulon Walton 19 7,703 09-08-2023, 08:28 AM
Last Post: jessencan
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,308 09-05-2023, 11:16 AM
Last Post: nickolas
  Mobian boot failed with zstd message after upgrade. Mahgue 0 733 09-01-2023, 11:29 AM
Last Post: Mahgue
Big Grin An early xmas present: 6.1 kernel treebeard 28 10,742 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to update mobian over tor vusra 13 7,382 07-09-2023, 08:57 PM
Last Post: vusra
  how to disable ipv6 at kernel level with towboot? vusra 2 1,008 07-09-2023, 01:25 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 2,847 05-12-2023, 08:09 AM
Last Post: zetabeta
