04-10-2016, 04:08 AM
(04-09-2016, 11:38 PM)tllim Wrote: The issue was due to an older version of Ethernet driver been installed. They have checked on the longsleep finding but the high_mem flag already set on current code and puzzle what still can causing the boot up issue (it is not memory panic like longsleep observed but a no end loop in boot up process).
Huh what high_mem flag? Can we expect a new BSP then or where does a new Ethernet driver come from? Also if the integer overfow in the driver not in the version from Remix, where did that version come from? You should double check with them as this indicates that the problem was not understood.
