No microphone input in Remix
I saw posts here saying that headset microphones should work, but so far Remix isn't recognising any of my own headsets or a 4-pole TRRS type headphone adapter with mic that I've just bought. I've tested using the sound recorder and Google voice search. Is this a known issue with the Android and/or Remix distributions, or do I possibly have a fault?
(07-02-2016, 08:10 AM)xtcrefugee Wrote: I saw posts here saying that headset microphones should work, but so far Remix isn't recognising any of my own headsets or a 4-pole TRRS type headphone adapter with mic that I've just bought. I've tested using the sound recorder and Google voice search. Is this a known issue with the Android and/or Remix distributions, or do I possibly have a fault?
There are apparently two configurations for the 4 port headphones, I'm planning to try this in an effort to get "Ok Google" working on the Android build Pine64:-
https://www.youtube.com/watch?v=g6AZF8v0FLY
Maybe (if we're (Pine64 owners) are lucky) one will work and allow us to use an external mic Smile.
If you get it working please do let me know, but I've also tried bluetooth headsets and they don't work in Remix either, so the problem may be with the OS rather than the hardware.
I think the current version of RemixOS on the Pine doesn't have a configuration option for audio input. Alternatively, I had no trouble getting the Pine to recognize audio input (via USB input even) when I booted up Debian. So, I think it's the OS, not the card.
  sourround sound - Remix MrSarkasmus 0 2,860 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 44,269 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 4,306 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 165,223 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 4,772 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 4,707 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 19,408 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 24,587 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 8,909 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 4,292 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
