I2S Audio patches for Pine64+ uploaded to GitHub
I took my work to enable audio over the I2S port and put it on github to share with everybody.  Enjoy if you want.  I started from the Armbian patches for the legacy kernel used for Ubuntu 16.04 xenial.  I only changed the DTS for the Pine64+ boards because that is what I am using.  I have a Pine64 512MB board, but haven't tried it, yet.  Enjoy: https://github.com/looperlative/linux-pine64-armbian
Latest version can correctly play audio on the mikroelektronika WM8731 board. "plughw:" translation from 24_3LE to 24_LE seems to be broken on this version of Armbian. Haven't looked yet to see where the bug is. If you stick to S16_LE, S24_LE and S32_LE modes, then audio works perfectly.
  Programming languages support under PINE64 baryluk 6 20,756 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,837 11-13-2019, 09:41 AM
Last Post: roel
  Manjaro arm on pine64+ roel 2 10,705 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,354 03-22-2019, 09:25 AM
Last Post: llungster
  Pine64: Minimal SDL config Max11 3 10,162 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,516 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,992 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,658 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,699 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,298 10-26-2017, 05:51 PM
Last Post: gregjo
