Android 7.1 (SOPINE)
Android 7.1 (SOPINE) v0.3.10-r66
Dear Admin,
PL. Inform that if GPIO Library for Pine64LTS are available for android
The LCD does not work on this one.
Can't make this image work - I get just reboot loop in u-boot.
U-Boot 2014.07 (Jul 18 2017 - 16:19:17) Allwinner Technology
uboot commit : 13dcbb66e9d12eea804ab8a35e29ecdb3025967c
normal mode: with secure monitor
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
[      0.380]pmbus:   ready
[SCP] :wait arisc ready....
[SCP] :arisc version: [sun8iw5_v0.03.00-227-gcec3a2b]
[SCP] :sunxi-arisc driver v1.10 startup ok
pmu type = 0x11
[      0.399]PMU: AXP81X
[      0.399]PMU: read AXP81X 84H=0xf2
[      0.401]PMU: write AXP81X 84H=0xf6
[      0.404]PMU: AXP81X found
factory
axp end
run key detect
no key found
no uart input
DRAM:  2 GiB
fdt addr0: 0xb6e78578
fdt addr1: 0xb6e8b1f8
Relocation Offset is: 75ede000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[cpu1]secondary entry
[      0.508]power on secondary cpu
set power on vol to default
[      0.514]flash init start
[cpu1]dcdc1_vol = 3300, onoff=1
workmode = 0,storage type = 1
[cpu1]dcdc6_vol = 1100, onoff=1
[      0.524]MMC:        0
[cpu1]aldo1_vol = 2800, onoff=0
[      0.529]mmc init start to delay
[cpu1]aldo2_vol = 1800, onoff=1
[cpu1]aldo3_vol = 3000, onoff=1
[cpu1]dldo1_vol = 3300, onoff=0
[cpu1]dldo2_vol = 3300, onoff=0
[cpu1]dldo3_vol = 2800, onoff=0
[cpu1]dldo4_vol = 3300, onoff=1
[cpu1]eldo1_vol = 1800, onoff=1
[cpu1]eldo2_vol = 1800, onoff=0
[cpu1]eldo3_vol = 1800, onoff=0
[cpu1]fldo1_vol = 1200, onoff=0
[cpu1]fldo2_vol = 1100, onoff=1
[cpu1]gpio0_vol = 3100, onoff=0
[cpu1]find power_sply to end
[cpu1]dcin exist
[cpu1]no battery exist
[cpu1]on cpu2
[cpu1]on end
[cpu2]third entry
[      0.578]start
[cpu1]drv_disp_init
[cpu2]bmp file buffer: 0x47400000, bmp_info.buffer: 46400000
[cpu2]kill cpu 2
[cpu1]init_clocks: finish init_clocks.
[cpu1]fail to get clk for lcd1
[cpu1]clk_set parent tcon1 fail
[cpu1]clk_set parent pll_mipi fail
[cpu1]pwm_request:pwm number = 1
[cpu1]pwm_request: reg = 0x1f03800. pwm = 16.
[cpu1]request pwm success, pwm = 16.
[cpu1]enable power vcc-hdmi-33, ret=0
[cpu1]drv_disp_init finish
[cpu1]Hekang Debug get partno failed!
[cpu1]** Bad device specification sunxi_flash -1 **
[cpu1]load file(hdmi.txt) error
[cpu1]boot_disp.output_disp=0
[cpu1]boot_disp.output_type=1
[cpu1]boot_disp.output_mode=4
[cpu1]fetch script data boot_disp.auto_hpd fail
[      1.036]mmc init end to delay
[cpu1]disp0 device type(1) enable
[mmc]: mmc driver ver 2016-03-31 15:50:00
[cpu1]enable
I bought one PINE A64 LTS board and one PINE64 LCD module but still none of android image is not working for LCD display apart from opensuse linux image. any idea?? i changed uEnv.tx to disp0_screen=lcd also but that did not help.
(12-01-2019, 07:04 AM)puneet Wrote: I bought one PINE A64 LTS board and one PINE64 LCD module but still none of android image is not working for LCD display apart from opensuse linux image. any idea?? i changed uEnv.tx to disp0_screen=lcd also but that did not help.
https://wiki.pine64.org/index.php/SOPINE...0170726.5D
This is Android 6.0 build.
  Struggling to get Android running qwe 1 3,793 11-09-2022, 05:29 AM
Last Post: Little_Johnny
  EMMC with Android on Sopine koekoeboy 1 7,850 05-29-2020, 11:42 PM
  Android 6.0.1 (PINE A64-LTS / SOPINE) pineadmin 4 12,655 12-30-2018, 08:36 PM
Last Post: wombat
  How to get & compile Android 5.1 for Pine A64-LTS spbrain 2 9,079 09-17-2018, 02:55 AM
Last Post: slapin
  LCD not functioning with A64-LTS/SOPINE icullumber 14 35,280 05-04-2018, 06:30 AM
Last Post: Serper
  Compile kernel /Android and can't detect SDHC from Kernel spbrain 6 18,323 01-25-2018, 05:34 AM
Last Post: Luke
  When will Remix OS be available for sopine? Will. 0 4,978 04-26-2017, 02:25 AM
Last Post: Will.
