Compile kernel /Android and can't detect SDHC from Kernel
Hello?
I found how to compile compile pine64 android 5.1.1 from https://gitlab.com/pine64-android/manifest/wikis/home.
I modified some parameters (LPDDR3 define from uboot) and I made sun50iw1p1_android_Baomi-db1000_uart0.img and write to sdcard using Phoenix program(Start Up Option).
Then finally confirmed the boot screen.
But Strangely, system.img was not mounted.
console output is
  30.041548] fs_mgr: __mount(source=/dev/block/by-name/system,target=/system,type=ext4)=-1
[   30.050642] fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/by-name/system at /system options: (null) error: No such file or directory
[   49.727478] fs_mgr: check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=-1
[   49.735547] fs_mgr: begin to format ext4 buffer : /dev/block/mmcblk0p10[   49.743178] fs_mgr: Not running /system/bin/e2fsck on /dev/block/by-name/cache (executable not in system
And Kernel Parameters
[    0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c28000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p7 init=/init partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6Confusedystem@mmcblk0p7:misc@mmcblk0p8:recovery@mmcblk0p9:cache@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:alog@mmcblk0p13:UDISK@mmcblk0p1 cma=384M androidboot.selinux=permissive androidboot.serialno=74005034440c080b038e androidboot.hardware=sun50iw1p1
And I found problem log from kernel message.
As Image from offical site "http://files.pine64.org/os/SOPINE/android/android-ver5.1.1-20160630-sopine-8GB.img.gz",
Linux Kernel found "mmcblk0".
Log is
9.929729] mmc0: new high speed SDHC card at address 59b4
9.930831] mmcblk0: mmc0:59b4 USD00 29.5 GiB
But compiled linux kernel can not found SDHC card.
I tried 8GB SDHC Card but it same.
What do I modify bootloader config or kernel ??
How do I fix this problem?
SD Card Init Log is below from kernel and no detect SDHC card
[    8.730445] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  3 2018 at 09:36:58
[    8.743342] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[    8.750009] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[    8.756760] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[    8.763920] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[    8.770110] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[    8.776929] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[    8.782910] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    8.793861] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[    8.816982] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    8.846524] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000ba000 irq:92
[    8.853803] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Jan  3 2018 at 09:36:58
[    8.866672] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[    8.873611] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[    8.880656] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[    8.887695] get() with no identifier
[    8.891594] get() with no identifier
[    8.895491] get() with no identifier
I solved this problem.
I found sys_config.fex from andorid 6.0 for SOPINE and compare this version.
I fix some parameters and values and finally SDHC is detected.
I saw android screen successfully!
(01-03-2018, 12:55 AM)spbrain Wrote: Hello?
console output is
Log is
(01-05-2018, 01:12 AM)spbrain Wrote: I solved this problem.
Hi spbrain
I am having some problems with compile android for SOPINE too.
1. I can't do "repo sync' for lichee branch as in  https://gitlab.com/pine64-android/manifest/wikis/home instructions. Many '404' errors occured:
manhbt@HP:/media/DATA/AOSP/Pine64/lichee$ repo sync
Fetching project repo
Fetching project tools
Fetching project linux-pine64
Fetching project buildroot
Fetching projects:  16% (1/6)  Fetching project linux-3.10
error: RPC failed; result=22, HTTP code = 404
fatal: The remote end hung up unexpectedly
Fetching projects:  33% (2/6)  Fetching project brandy
error: Cannot fetch brandy
error: Cannot fetch linux-3.10
error: Cannot fetch buildroot
error: Cannot fetch tools
error: Exited sync due to fetch errors
2. I also tried for all android SDK 6.0 downloaded from wiki page, compiled and write to SD card successfully, but the board can not booted properly.
You can see the boot log here: https://pastebin.com/MXrjyLuF
I think problem was in my sys_config.fex file. Can you share me your working sys_config.fex file? and many thanks if you can share me your experiences in how to download & compile android for SOPINE. I am very tired and so disappointed with PINE64 documents and SDK, very very poor support information. Please help me! Sad
Thank in advance,
Manh
Hi Manh and welcome to the forum. Please post just once (posts from new members are moderated). We're getting to new members posts as soon as we can. Please read the forum rules to learn more.
console output is
Log is
(01-24-2018, 05:12 PM)Luke Wrote: Hi Manh and welcome to the forum. Please post just once (posts from new members are moderated). We're getting to new members posts as soon as we can. Please read the forum rules to learn more.
Dear Luke,
I am sorry for my inconvenience.
Regards,
Manh
Nobody can help me??
(01-25-2018, 05:29 AM)manhbt Wrote: Nobody can help me??
Think your best option is to join IRC and ask ayufan for pointers.
  Struggling to get Android running qwe 1 3,235 11-09-2022, 05:29 AM
Last Post: Little_Johnny
  EMMC with Android on Sopine koekoeboy 1 7,237 05-29-2020, 11:42 PM
  Android 7.1 (SOPINE) pineadmin 5 15,487 12-01-2019, 01:53 PM
  Android 6.0.1 (PINE A64-LTS / SOPINE) pineadmin 4 11,591 12-30-2018, 08:36 PM
Last Post: wombat
  How to get & compile Android 5.1 for Pine A64-LTS spbrain 2 8,345 09-17-2018, 02:55 AM
Last Post: slapin
