hope its ok to post my problems here
Problem 1:
I tried to install
-leia24
-some nightbuilds from test.libreelec.
They doint boot from eMMC (Red + White led lit forever and nothing happens) I only can boot them if i insert a SD-Card, Install a Jumper on eMMC "pins" and remove the jumper directly when i start.
Or if i install leia21 -> Boot -> go into a linux build -> mount the eMMC p1 and the img from the libreelec build i want and copy the Image / System files to the eMMC (replace them from the installed leia21 build)
Problem 2:
I got Inputstream.adaptive running (why is it not in all this builds ...?)
If i have hardware acceleration - PRIME active and Try to change the Source, i got a blackscreen my monitor says no signal. And i never get the image back (need to restart)
In the logs i get WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
If i deactivate hardware acceleration, it works without any problems (only 90-100% cpu load..)
If i now reactivate hardware acceleration, the video starts playing with the settings i set before. But when i close it / it ends. Same behaviour (blackscreen and only restart helps)
Is there a solution that i can add ?
Problem 1:
I tried to install
-leia24
Problem 2:
