How can I reliably get battery status on pinebook
thanks to the great Q4os developers I now have a quite decent Debian Stretch system running.  After I managed to flash the eMMC with Q4os I simply editet sources.list to point to Stretch instead of Jessie and did a dist-upgrade.   I needed to fiddle a bit with the graphics since X was lost but rebuilding libump and xf86-video-fbturbo under Stretch did the trick.  (I'm a Debian developer and might consider creating at least an official libump package - need to check the license of fbturbo whether it is acceptable in Debian.)
I now try to get some reliable information about the battery status.  I'm using xfce4 but the battery plugin always says the battery is empty (even if I get a desktop notification that the battery is full when plugging in power adapter.
The command acpi does not work.
How do others check the battery status on pinebook?
Kind regards
        Andreas.
Does q4os also have the 'sudo pine64_health.sh' script? Because there you can see it reliably.
(09-19-2017, 02:00 PM)joekinley Wrote: Does q4os also have the 'sudo pine64_health.sh' script? Because there you can see it reliably.
If it doesn't have that script, you can download it from here. Or if you just want battery info, you can use this script that I wrote. I run it on the pinebook with using a screenlets terminal widget to have it stuck on the desktop for when I'm testing stuff and want to seem some more stats than just 'how charged / how flat' is the battery. Wink ACPI doesn't work on the pine64/pinebook as ARM doesn't have ACPI... instead you query the '/sys/class/power_supply/battery/' path for current usage, voltage, and charging or discharging, and percentage charge.
[battery]
label=
command=tail "/sys/class/power_supply/battery/capacity"
I add this to my i3block cfg file and it is working perfect for me
I run a Debian-based distro also, and 'acpi' and 'acpi -V' would mot work until I installed  it with
'apt-get install acpi'.   [You may have to use 'sudo apt-get install acpi']
'acpi -V' (note the space) is the "verbose" version, which also gives you the current health of your battery, i.e., percentage capacity now vs. original design (new) capacity. Great command-line utility to have.
I have no particular solution for your OS and xfce4, but can point you to my solution for LXDE/lxpanel on Armbian 5.86 with a very similar problem:
Display battery charge value with LXDE and lxpanel
Moreover, the current Armbian release 5.86 with Ubuntu bionic utilizes xfce as well. The power manager of xfce displays battery charge information correctly, so that you could check whether you find your solution in the internal configuration of xfce on Armbian 5.86.
  DietPi OS for Pinebook MichaIng 3 5,606 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 63,397 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 1,049 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 820 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 4,039 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,335 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 4,028 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,370 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,891 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,878 12-25-2020, 04:40 PM
Last Post: ford442
