08-02-2016, 10:56 PM
(This post was last modified: 08-02-2016, 10:57 PM by jodybrown99.)
i bought this:
http://www.ebay.ca/itm/151985309073
FFC FPC 30-pin 0.5mm Pitch Ribbon Cable line ZIF HDD+Adaptor extend connector
totally works. worth the $4.
now, as you can see, that comes with the extending adapter, which you already have. so...
i also bought this:
http://www.ebay.ca/itm/311530317516
20Pcs 0.5mm Pitch 6 Pin AWM 80C 60V VW-1 Flexible Flat Cable FFC FPC 200mm
yeah, that's 20 of them. but i couldnt find less than that for any better price. getting just 1 was the same price as 20.
and i used the extending adapter from the other purchase to connect it
and now both cables for my lcd are really long and easy to work with.
i also bought this:
