Pine Arrived; No Sound in Remix Using HDMI
Hi there.
My Pine just arrived.  When I fired it up on Remix everything seems to work but I am not getting any sound from a TV connected using HDMI.
Any thoughts on what I am doing wrong?
Thanks.
Have you tried Android?
You're probably not doing anything wrong... you might check all your TV settings, and you might try another HDMI cable; and get a quality cable, the shorter the better. 3-6 ft.. 1m.
Is your monitor a flat panel TV, old style TV... have you tried *all* TV settings for audio?
marcus
I have a 2 GB Pine.
I haven't tried Android yet. I did order an SD card with Android. I don't want to open it until a shipping related issue is resolved.
I have a flat panel TV. The cable is one an HDMI switch that works correctly with several other computers (both video and sound). The video part works fine with a Pine.
On the TV I have check for muting and turned the volume to the maximum. When you say to check the TV settings, could you be more specific what you are referring to?
  pine store paulhide 1 5,265 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 8,739 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 12,156 09-10-2019, 11:28 AM
Last Post: Pineapple
  First Boot HDMI/USB problem reefer 1 7,040 11-18-2018, 10:32 PM
  PINE A64+ 4K Media Computer RWL 4 10,435 11-08-2018, 04:20 PM
Last Post: mindwave
  Sound teddyj 4 9,971 11-02-2018, 02:28 PM
Last Post: crw
  Multi Room Audio - Pine style mjgoode 4 13,302 09-19-2018, 10:30 AM
Last Post: mjgoode
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,117 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 7,858 12-26-2017, 07:01 PM
  Pine64 Ubuntu Mate No Sound adamjedgar 3 10,573 11-06-2017, 02:53 AM
Last Post: Luke
