Can't boot PINE64+ 2GB
Question
Hi! I'm in trouble with startup my new PINE64+ 2BG.  Smile
What I'm doing?
I downloaded RemixOS from here and I have tried to burn it using PhoenixCard but Script not found error occured. So I used HP USB Disk Storage Format Tool I everything seems to be ok. The SD card Adata 32GB Class 10. When I have plugged in the monitor and then the charger, the red LED indicator is on and...nothing happens. I tried many times with 2 different monitors. First of them say Out of range 67.5KHz/60Hz and the second - No signal. What can be a problem?
(06-24-2016, 12:47 AM)micobg Wrote: Hi! I'm in trouble with startup my new PINE64+ 2BG.  Smile
What I'm doing?
Script Not Found error is due to trying to burn a DD image using PhoenixCard software. See:
http://forum.pine64.org/showthread.php?tid=1146
As for the monitors, it seems on the face of it that they use a resolution that the OS doesn't recognise. Only 720p and 1080p will be recognised by RemixOS. There are also issues using things like HDMI to DVI/VGA adapters.
If you can, try connecting to a HDMI television rather than a monitor.
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 285 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,345 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,783 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,631 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,758 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,842 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,558 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,253 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,328 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,203 10-18-2020, 01:41 PM
Last Post: toiny
