Official Debian support!
#81
Here's where you should report the problem:
https://www.debian.org/releases/stable/i...submit-bug
It's probably worth testing and reporting whether using a microsd card vs. emmc makes any difference. Some people have found that one works where the other fails on this device.
I was finally able to install (current) Debian bookworm on my RockPro64 !
The big missing part for me was that (a recent) uboot needed to be installed in SPI memory,
which makes subsequent Debian installations much easier since the Debian Installer doesn't install uboot by itself.
I documented the installation procedure here: https://0xacab.org/varac-projects/doc/-/...ial-debian
Hope it works for everyone else here !
(08-16-2023, 01:32 AM)varac Wrote: The big missing part for me was that (a recent) uboot needed to be installed in SPI memory,
Debian's u-boot-rockchip package now supports the RockPro64 v2, too.
With that, I was able to create a fresh bootable microsd card by populating a GPT partition with the kernel, initrd, dtbs, and extlinux files, and running u-boot-install-rockchip /dev/devicename .
Note that the partition must not start before the 16MiB mark, because the space before that is where the bootloader files are written. I think it requires the bootable flag to be set, too.
https://opensource.rock-chips.com/wiki_Partitions
It's also helpful to put a script in /etc/kernel/postinst.d and /etc/kernel/postrm.d to automate copying the new .dtb file to the boot partition whenever a new kernel is installed.
#!/bin/sh
# This script installs RockPro64 devicetree files into /boot when new kernels
# are installed, removes them when kernels are removed, and updates the
# "dtbs" and "dtbs.old" symlinks accordingly.
# It should be copied into /etc/kernel/postinst.d/ and /etc/kernel/postrm.d/
# and given execute permission.
# https://www.debian.org/doc/manuals/debian-kernel-handbook/ch-update-hooks.html
set -e
exec </dev/null >&2  # Don't use stdin or stdout
version="$1"
pkgname=${DPKG_MAINTSCRIPT_PACKAGE:-kernel package}
if [ -z "$version" ]; then
    echo "W: $pkgname did not pass a version number; exiting."
    exit 0
fi
eval set -- "$DEB_MAINT_PARAMS"
action="$1"
# return 0 if $1 matches any of the remaining args
among() {
    val="$1"
    shift
    for a in "$@"; do
        if [ "$val" = "$a" ]; then return 0; fi
    done
    return 1;
# update /boot/dtbs and /boot/dtbs.old
# expects $1 to be "configure" or "remove"
# expects $version to be set
# see also: linux-update-symlinks
update_symlinks() {
    # build a list of dtbs-<ver> symlink targets, highest priority first...
    # ...first priority is a newly installed kernel
    if [ "$action" = configure ]; then
        set -- "dtbs-$version"
    else
        set --
    fi
    if [ "$action" = remove ]; then
        rmtarget=dtbs-$version
    fi
    # ...next priority is the existing primary symlink (if not being removed)
    link1=/boot/dtbs
    target1="$(readlink "$link1" || true)"
    if [ -e "$link1" ] && ! among "$target1" "$@"; then
        if [ "$target1" != "$rmtarget" ]; then
            set -- "$@" "$target1"
        fi
    fi
    # ...next priority is the existing secondary symlink (if not being removed)
    link2=/boot/dtbs.old
    target2="$(readlink "$link2" || true)"
    if [ -e "$link2" ] && ! among "$target2" "$@"; then
        if [ "$target2" != "$rmtarget" ]; then
            set -- "$@" "$target2"
        fi
    fi
    # ...finally, any other installed kernels, newest first
    for v in $(linux-version list | linux-version sort --reverse); do
        if [ "$action" = remove ] && [ "$v" = "$version" ]; then
            continue;
        fi
        if ! among "dtbs-$v" "$@"; then
            set -- "$@" "dtbs-$v"
        fi
    done
    # create/replace/remove the primary and secondary symlinks
    if [ $# -ge 1 ]; then
        echo "I: creating symlink $link1 -> $1"
        ln -sfn "$1" "$link1"
    elif [ -L "$link1" ]; then
        echo "I: removing $link1"
        rm -f "$link1"
    fi
    if [ $# -ge 2 ]; then shift; fi
        echo "I: creating symlink $link2 -> $1"
        ln -sfn "$1" "$link2"
    elif [ -L "$link2" ]; then
        echo "I: removing $link2"
        rm -f "$link2"
    fi
    if [ ! -e "$link1" ]; then
        echo "W: $link1 symlink is missing; unable to find a target for it"
    fi
srcdir=/usr/lib/linux-image-${version}/rockchip
destbase=dtbs-${version}
destdir=/boot/$destbase/rockchip
fname=rk3399-rockpro64-v2.dtb
    if [ -f "$srcdir/$fname" ]; then
        echo "I: installing $destdir/$fname"
        mkdir -p "$destdir"
        cp "$srcdir/$fname" "$destdir/$fname"
    else
        echo "W: $pkgname doesn't contain $srcdir/$fname; making symlink anyway"
    fi
    update_symlinks "$action"
fi
    if [ -f "$destdir/$fname" ]; then
        echo "I: removing $destdir/$fname"
        rm "$destdir/$fname"
        rmdir "$destdir" || true
        rmdir "/boot/$destbase" || true
    fi
fi
I was trying this out today and it seems to work well.
One question: how can I change the resolution? I am guessing that has to be done at boot but I can't find anything in /boot to configure.
(12-16-2023, 03:00 PM)foresto Wrote: [code]#!/bin/sh
I have edited that post to contain the latest version of the script. It is now smart enough to create a new /boot/dtbs.old symlink when a kernel is removed and the existing dtbs.old becomes dtbs. (It uses the same logic as used for the other symlinks in /boot.)
  official support for aarch64 in OpenArena Opvolger 0 1,663 03-24-2022, 02:23 PM
Last Post: Opvolger
  Fedora 32 Release, improved support for Rock(Pro)64 Tharadash 2 6,014 05-05-2020, 08:37 AM
Last Post: zer0sig
  Kickstarter: Allwinner VPU support in the official Linux kernel xalius 8 15,187 10-03-2019, 03:03 AM
Last Post: bunkerWHz
Exclamation First images with DRM and Mali support for A64 Luke 74 121,701 04-27-2018, 10:22 PM
Last Post: Max11
