sudo nano file saving pinephone beta edition
I have run into a simple yet gamebreaking issue. My virtual keyboard does not recognise the ctrl+x input that would allow me to save changes in files. or rather.
I've run into the issue of the screen shutting off after a half second when not on charge (and only when not charging), but have been trying to manually change the screen settings in powermanagementprofilesrc file. but because I cannot save my changes, my phone is unusable when not on charge. what could I possibly be doing wrong?
I am running kde plasma, for reference. and let it be known I am a recent convert from windows and ios, and have minimal knowledge of linux.
(12-15-2022, 10:41 PM)CharlesGnarley Wrote: I have run into a simple yet gamebreaking issue. My virtual keyboard does not recognise the ctrl+x input that would allow me to save changes in files. or rather.
See this: https://forum.pine64.org/showthread.php?tid=15216
That did the trick, thanks heaps.
For posterity if that thread gets taken down, the solution is to press control then press escape twice and THEN hit x
No idea why using the konami code makes it work, but it is what it is
Quote:For posterity if that thread gets taken down, the solution is to press control then press escape twice and THEN hit x
No idea why using the konami code makes it work, but it is what it isgeometry dash subzero
I tried that but it didn't work?
For the record, the most convenient way under Plasma Mobile to set power management settings that the mobile settings page does not support (e.g., to never suspend the phone when it is plugged in) is to force bringing up the desktop version of the settings with kcmshell5 powerdevilprofilesconfig.
  Pinephone won't boot. spha 13 3,390 05-15-2024, 10:31 PM
Last Post: Richy_T
  Pinephone boot. Richy_T 5 349 05-15-2024, 03:35 PM
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,894 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 1,125 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 575 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 390 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 113,980 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,168 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 790 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,875 12-28-2023, 07:55 AM
Last Post: MTXP
