Quartz64 Model A fan
Hi, I recently purchased a Quartz64 model A 4GB and installed DietPi using a 32gb SD card. Once done with setup, I installed it in its case and connected a fan (which I bought from the pine store) to the 2 pin connector on the board. The fan does not function. Do I have to install a fan controller? If so, would anyone have recommendations?
(05-19-2023, 08:18 PM)TeutonicTovarish Wrote: Hi, I recently purchased a Quartz64 model A 4GB and installed DietPi using a 32gb SD card. Once done with setup, I installed it in its case and connected a fan (which I bought from the pine store) to the 2 pin connector on the board. The fan does not function. Do I have to install a fan controller? If so, would anyone have recommendations?
AFAIK it works OOTB, but it only spins when needed (>55C IIUC).
https://wiki.pine64.org/wiki/ROCKPro64#Working_Features does mention ATS - Active Thermal Service so you could try that
  A large 3d printable case for Model A, or a dimensioned drawing of the PCB? Randomuser 1 98 05-24-2024, 08:11 AM
  gpio on Quartz64-a jyoung 3 720 05-24-2024, 06:41 AM
Last Post: Randomuser
  Is the USB 3.0 port still an issue for Q64 model A? andreas1107 3 1,594 12-11-2023, 09:27 AM
Last Post: diederik
  SOQuartz Model A baseboard Real-Time Clock stormwyrm 1 541 11-19-2023, 01:04 AM
Last Post: stormwyrm
  Survey for Model B Owners: Stereo Audio HAT CounterPillow 1 1,293 03-01-2023, 05:48 AM
Last Post: manning
  Is Quartz64 compatible with official 7'' Raspberry Pi display? maldus 1 1,158 02-05-2023, 09:28 AM
Last Post: CounterPillow
  SD card slot in Quartz64 model B psic4t 1 1,053 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,311 10-13-2022, 07:43 PM
Last Post: dml-pc
  3D Model / Technical Drawings pitchbent 2 1,762 10-05-2022, 02:01 PM
Last Post: pitchbent
  RockPro64 NAS case compatibility (Model A) flocke 2 2,266 06-12-2022, 10:33 AM
Last Post: flocke
