RockPro64 linux console video mode
I have a weird issue with the linux console.  I am trying to setup a rockpro64 and in doing that I am using an old Dell monitor with a 1680x1050 resolution.
When the rockpro64 boots, the first thing that I see is the output from uboot. This is OK. Then linux is booted and for a short time I see a patterned screen. After this, there is the linux boot output.
The issue is that as soon as uboot gives control to the linux kernel, the display becomes terrible: all trembling and slightly distorted. The monitor reports that the output is at 1400x1050@55Hz, which is obviously not correct. However, /sys/class/graphics/fb0/modes correctly shows U:1680x1050p-0.
Obviously, I suspect that the poor display is due to using an output format that is not suited for the monitor. However:
  • Why does uboot pick the right display mode and linux does not?
  • What would be the proper way to instruct linux to use a more correct display mode for its console?
Note that the issue seems to be cross-distro (tested with debian and manjaro).
Thanks for any help,
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 11 19,434 03-07-2026, 09:32 AM
  [Manjaro] Fixing /etc/fstab from serial console while using lvm2 Dendrocalamus64 0 658 10-16-2025, 05:58 PM
Last Post: Dendrocalamus64
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 162,691 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,639 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,315 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 9,092 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,058 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 39,692 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 121,598 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 7,056 07-14-2023, 04:22 AM
Last Post: hunderteins
