Pinebook Pro shows only bright white screen when powered on
Question
I received my Pinebook Pro in Spring 2021.  I last used it about one month ago, and left it disconnected.  So, the battery has completely drained.
I've been charging it using the barrel charger for more than twelve hours.  When I turn it on, the green power light comes on, and the screen comes up bright white.  After ten seconds or so, the backlight dims a bit so it's a softer white.  At that point, I can do things like toggle num lock on my external keyboard.
I don't think it is an OS issue, because it booted completely fine a month ago and I haven't touched it.  But just in case, I am using hand-debootstrapped Debian "bullseye" with a custom kernel build using Manjaro's patches as of a year ago, and stock Debian u-boot.
Any ideas about what these symptoms could indicate?  Really hope it is not bricked!  I don't have UART, but I could get one if it's not just that the screen is completely dead.
Thanks.
Why not try a different OS on SD card?
:wq
Fair, I put in an SD card with Armbian, but it was no different, unfortunately.
(07-22-2022, 01:20 AM)KC9UDX Wrote: Why not try a different OS on SD card?
Even easier, no guarantees.....
Try a hard power off,,,/ hard reset,, in that order
try start up between
(press power button (and hold),, 6-7s,,,/ 20+s)
  Updated Pinebook Pro? tantamount 2 1,417 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 6,985 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,236 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 2,397 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 5,885 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 9,496 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,434 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,153 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,697 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 28,058 03-09-2025, 11:17 AM
Last Post: davisthomas
