Android 11 ATV
Android 11 ATV build
gapps not fully working googleplay wont work yet apps can be added through uptodown app or usb etc
inspired by the builds of mo123 for other devices i am trying to make a ATV build for the Quartz64-a
only from google login issue it is working nice on my device
4K,HDR, wifi etc
some cooling is advised
gpt image wich you can flash on sd or emmc
dts used :
https://github.com/Shaggy013/diesel/blob...tz64-a.dts
android 11 source with rockchip sdk  (just google )
added gapps https://github.com/opengapps/aosp_build
android box configs:
https://github.com/Shaggy013/diesel/blob...dConfig.mk
https://github.com/Shaggy013/diesel/blob...56x_box.mk
gpt image
https://drive.google.com/file/d/1tGIoHn4...sp=sharing
Update
kernel updates
added codec profiles (Rockit is updated)
npu activated
added internal drives configure
more bootoptions for android sata,nvme etc.
remove almost all rockchip apps
Google Apps login works after you spoof the device with the added module for Magisk
boot.img already patched with Magisk (activate magisk from menu ,update and reboot for su )
https://drive.google.com/file/d/1tXLUFaa...sp=sharing
major diffrence with 12 is that hdr works on 11
.zip   ADT-3-11.zip (Size: 3.55 KB / Downloads: 400)
Update
Enabled pcie
enabled DSI (not checked)
split in a sata and usb3 since the newer quartz got only usb3
Sata
https://drive.google.com/file/d/1WExTvjm...sp=sharing
Usb3
https://drive.google.com/file/d/1hekaYLP...sp=sharing
  Android on SOQuartz alistson 2 14,264 10-29-2024, 01:27 PM
  Android 12.1 Kernel 5.10 Quartz64-a shaggy013 2 7,298 12-08-2022, 06:52 PM
Last Post: shaggy013
  Android SDK Build. west0330 1 3,828 12-01-2022, 10:55 AM
  Android 12 L Quartz64 and Quartz64pro shaggy013 13 18,757 09-22-2022, 08:00 AM
  Android 11 4k HDR shaggy013 6 9,653 05-17-2022, 10:10 AM
Big Grin Android 12 Tablet , Box/Atv shaggy013 3 7,493 05-17-2022, 09:19 AM
  Can't compile Android 11 from SDK dieselnutjob 8 15,321 02-17-2022, 08:53 AM
Last Post: Firesped
  Android SDK download keaton 2 6,830 11-23-2021, 03:20 PM
Last Post: keaton
