Android 11 4k HDR
Android 11.2
build with a more recent sdk for android 11
working
HDMI
4k
HDR
lan , wifi
sata (first format it through usb )
usb
ir ?
Playstore works so you can udate and add programs  it is a older playstore so sure it updates Smile but it works to normal update android
like youtube kodi etc included
added leanback launcher to have a little box experiece with the tablet build .
todo
cec ( it works in a box build , but i have no gtsv to make playstore work)
and some cosmetics to make it look nice
this is a gpt image wich  you can flash for example with etcher on a sd or emmc
https://drive.google.com/file/d/1PughXW8...sp=sharing
minimal 16gb sd/emmc
i wanted to clean it up some more but somehow my clock runaway from my board , so i cannot update it right away but thought i should at least share it
disabled setupwizard ?
enable cec ?
gpt:
https://drive.google.com/file/d/16CvOlAM...sp=sharing
rk-img
https://drive.google.com/file/d/12hHBJ1K...sp=sharing
disabled lockscreen
bluetooth ?
https://drive.google.com/file/d/1nCPKVo6...sp=sharing
and a try to build a quartz64-b without shematics and info from a mainline dts
https://drive.google.com/file/d/1o1AV4BD...sp=sharing
I'm working on a build for the rockpro64, do you know if the SDK could be made to work with that or how to find an SDK for the rk3399 that could be used? while I'd like to get the quartz64 I can't really afford it right now.
Also information on how to keep the SDK updated with rockchip updates would be nice as well, if you could clue me in. I've not really done an android build before. Seeing what i can learn.
(04-04-2022, 08:39 AM)Firesped Wrote: I'm working on a build for the rockpro64, do you know if the SDK could be made to work with that or how to find an SDK for the rk3399 that could be used? while I'd like to get the quartz64 I can't really afford it right now.
for rk3399 i dont knnow sure lot of sources for that thought even with mainline kernel .
and device examples plenty
i would say google and you find a lot
Between the times my memory wants to wakeup
Tablet build with gms
updates works
added kodi etc
https://drive.google.com/file/d/1mypdOKJ...sp=sharing
After rebirth of my Quartz64-a and finding some updates
interest for B versions ?
Updated
Gms to a more recent one
rockit updates some more video profiles
more boot device options , and the sata or pcie drive is now internal drive instead of a usb
Remove almost all rockchip apps so less network traffic Smile
boot.img already patched with Magisk
https://drive.google.com/file/d/146QGdR_...sp=sharing
  Android on SOQuartz alistson 2 13,565 10-29-2024, 01:27 PM
  Android 12.1 Kernel 5.10 Quartz64-a shaggy013 2 6,935 12-08-2022, 06:52 PM
Last Post: shaggy013
  Android SDK Build. west0330 1 3,545 12-01-2022, 10:55 AM
  Android 12 L Quartz64 and Quartz64pro shaggy013 13 17,403 09-22-2022, 08:00 AM
Photo Android 11 ATV shaggy013 2 6,047 05-20-2022, 03:25 PM
Big Grin Android 12 Tablet , Box/Atv shaggy013 3 7,021 05-17-2022, 09:19 AM
  Can't compile Android 11 from SDK dieselnutjob 8 14,195 02-17-2022, 08:53 AM
Last Post: Firesped
  Android SDK download keaton 2 6,445 11-23-2021, 03:20 PM
Last Post: keaton
