update kills keyboard
Keyboard was clipping along w/ the Manjaro Plasma 5.17.1-2-MANJARO-ARM that
came w/ the fon (plus a few upgrades) till a few days ago when a routine
upgrade took it down.  Unresponsive, and no kb151 showing up in dmesg. Doesn't
affect the fon.
Haven't found where kb151 is kept to save for manual install, what calls it or
when (doesn't show up in >cat /proc/cmdline), find doesn't find it, plocate
doesn't locate it, and the net is curiously mum but for two short references
on Megous.
I've flashed the ManjaroOS to an SD-card a few times and each time it boots
into a working keyboard.  Then an update will disable it.
From what I've gleaned online kb151 is a module that comes w/ the kernel, in
wh/ case it can't be activated if it's not there.
What's the fix?
Manjaro Plasma is "unstable" and the Phosh phone system will probably work better if you want stability with updates?
https://howtotrainyourrobot.com/pinephon...ith-phosh/
Exclamation No wIfI after Mobian update crakabeats 5 7,904 02-28-2026, 04:18 PM
Last Post: baptx
  keyboard and docking pad wigan 0 986 02-15-2026, 08:41 AM
Last Post: wigan
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,136 12-05-2024, 06:42 AM
Last Post: gilford
  Best OS for Physical Keyboard? jakfish 3 5,127 06-22-2024, 08:26 AM
Last Post: Peter Gamma
  pinephone virtual keyboard aular 4 4,782 04-10-2024, 03:45 PM
Last Post: aular
  Mobian PIN changed after update! Mwo87 21 33,710 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  PinePhone keyboard tones mlnease 10 12,195 04-29-2023, 11:29 AM
Last Post: mlnease
  Keyboard Remapping? jakfish 1 2,654 02-23-2023, 04:40 PM
Last Post: jakfish
  No longer waking up from sleep after recent update gamerminstrel 2 4,121 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  no sdcard boot and manjaro update failed Gwen 3 4,965 11-27-2022, 07:56 AM
Last Post: fxc
