RockPro64 Linux Manjaro HDMI 4K
Hmm...
Alright, I have two other ideas, @mkne :
- Change EnableHiDPI=false to true inside /usr/lib/sddm/sddm.conf.d/default.conf
- Switch from sddm to gdm as a default display manager: systemctl enable gdm.service --force
Currently I'm experimenting to update the Wayfire edition and Plasma-Mobile on pine64lts/ rockpro64 and sddm is giving me some problems there.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
(05-02-2020, 05:29 PM)PakoSt Wrote: Hmm...
Thanks, but no luck I'm afraid. It's a real shame...
This little ARM board is running KDE nicely on wayland and xorg with a mainline kernel.... Just fuzzy on a 4K monitor. On mainline, I'm not convinced the USB-C port is working, but that's a problem for another day...
The kernel initial boot is to 1080 in the console. All the other 4K capable SOCs detect the monitors "preferred" mode and run even the console at 4K. I noticed a patch here:
https://gitlab.com/ayufan-repos/rock64/l...w=parallel
I'm not sure if it's relevant to the Rockpro64, or not? I'm not sure if PINE64 have patches that will be added to the Mainline Kernel...
Do you think this is a Kernel issue?
Thanks,
Mkne
This piece is for the older 4.4 kernels (which aren't using Panfrost). But it's a nice find!
If it's from the kernel, then we ought to dig there a bit.
From what I can see, the RP64 is using the PBP kernel for the most part with Manjaro. It could explain why the display is defaulting to 1080p. Unfortunately I have no idea what to look for :|
On the USB-C - interesting, it doesn't work for me with Manjaro as well (haven't tried with one of the older distros yet). I'll install the official Debian image later today to see how it will behave there
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 17 Yesterday, 09:38 AM
Last Post: Yuriy Gavrilov
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 849 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 829 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,835 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 1,028 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 18,369 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 85,532 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,585 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 671 05-21-2023, 11:34 PM
Last Post: shpark
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,165 04-13-2023, 03:01 AM
Last Post: Reynold Grady
