bookworm vs trixie discussion for mobian in pinephone regular.
Thank you. Now, the internal speaker does no longer work (once again). I had the same problem with the headphone but using alsamixer helped.
Please can someone show me working alsamixer settings so that I can compare them with mine to find the culprit?
P.S: I've just solved my problem, enter "alsamixer -D hw:0", press m to unmute a channel, unmute both "Line out" and "DAC", the Debian wiki gave me the hint:
https://wiki.debian.org/AlsaMixer
I still get occasional crashes when playing videos in Mozilla Firefox. The internal speaker works but when I increase or decrease the volume, there's no immediate audio feedback whereas it still works with the internal earpiece.
If you have the same sound problem than me under Mobian Bookworm, unmuting some channels will be less dangerous than switching to Mobian Trixie.
P.S: I reproduce the freeze by using the command named "play" on a simple MP3 file, VLC and Lollypop freeze too.
Exclamation
Hello
I don't reproduce the freeze with the command named "play" but Mozilla Firefox still occasionally crashes when playing a video.
Yesterday, I found how to fix the audio feedback on the internal speaker when increasing and decreasing the volume, wrong default settings seem to be applied when choosing the internal speaker as the output device, "Line out Source" gets switched to "Stereo" instead of "Mono Differential" (main root cause, breaks the feedback) and "ADC Digital DAC" is unmuted (causes a nasty noise) whereas it should remain muted. I have to manually set the correct values each time the output device changes, which is cumbersome. I'll try to modify the faulty default settings.
(02-11-2024, 05:47 AM)anonymous Wrote: Please can someone show me working alsamixer settings so that I can compare them with mine to find the culprit?
I've been trying to fix mine for months... you've just helped me get a lot closer to fixing it!!!
What number values do you have on your settings, if you don't mind me asking? When I try to unmute Mic 1 I get loud static, especially if I have the charger plugged in
Sorry for the late reply.
Headphone 100
Headphone Source DAC
Line In 43
Line Out 100
Line Out Source Mono Dif
Mic1 43
Mic1 Boost 0
Mic2 43
Mic2 Boost 0
ADC Digital DAC Muted
AIF1 DA0 40 40
AIF1 DA0 Stereo
AIF1 Slot 0 00
AIF2 DAC 40 40
AIF2 DAC Source AIF2
AIF2 DAC Stereo Mix Mono
AIF2 Digital DAC Muted
DAC 40 40
DAC Reversed Muted
Earpiece 100
Earpiece DACR
warning, t64 transition has started to affect trixie/testing.
https://micronews.debian.org/2024/1709031141.html
this makes updating little more difficult. i cannot make any good advises. but manually selecting some t64 packages is basically way to go. program "aptitude" helps.
(04-25-2024, 06:49 PM)zetabeta Wrote: warning, t64 transition has started to affect trixie/testing.
I provided some tips here: https://forum.pine64.org/showthread.php?...#pid122140
At least with aptitude you can do the following:
aptitude safe-upgrade <pkg>
Which allows you to (safely) upgrade a specific package you 'need' to upgrade.
And generally: Just read what apt/aptitude is telling you and then use common sense to decide what to do. Remember: N(o) is a valid answer.
I have just done a full upgrade and I can no longer boot Sad Please help me.
(04-28-2024, 07:10 AM)anonymous Wrote: I have just done a full upgrade and I can no longer boot Sad Please help me.
if you would be locally (physically) nearby, let's look at it. knowing what is ahead, i think best course of action is to reinstall, and temporarily i suggest other than mobian.
however:
does it boot somewhere? so you can get virtual console, i.e. ctrl-alt-f3. (usb dongle and keyboaard is required)
does it get a internet through wifi? internet is not dependent on gui.
you probably do not have sshd installed, which can be used for remote management.
software "aptitude" helps, but you still need to know some thing about packages and their dependencies.
  atinout binaries for mobian/debian? NeutralGrey 2 153 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,217 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 190 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Phoch Trixie weekly install seems nice reTestability 0 248 03-10-2024, 08:47 AM
Last Post: reTestability
  unofficial kali linux for pinephone help needed pinesmell 5 3,800 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,191 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,917 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 674 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,849 08-31-2023, 12:38 PM
Last Post: vusra
  how to update mobian over tor vusra 13 7,239 07-09-2023, 08:57 PM
Last Post: vusra
