Pinetab 2 just arrived + when can hope to se wifi driver
(06-12-2023, 12:19 PM)Purple_Illusion Wrote: Thanks for the reply! I was able to install drivers on my other linux devices and got it working there.
Initial attempts at installing drivers on the pinetab2 did not succeed, but maybe that is a topic for another thread.
Looks like that driver is in the AUR, too. Yay could probably take care of the heavy lifting for you on building/installing it to the tab2.
I don't think they make them anymore, but the WiPi USB adapter that Raspberry Pi used to sell before they added wifi to the boards worked on the Pinetab2 for me right out of the box.
Hi, had the same problem on pinetabv2 as arrived and all my various ethernet to usb, and wi-fi dongles on short list would not pick. I have now purchased a tp-link usb type c to rj45 gigabit dongle UE300C(UN) P/N: 0101502037 via amazon uk based on someone saying it just worked - added to usb socket neareat power switch and it did indeed immediately work. Notified updates were available, so updated 508 items (all) today without problem. Quick rebook with a tp-link ac 1300 nano wi-fi plugged into very cheap simple usb hub and it immediately picked up and worked after password added. All working fine now on first wi-fi dongle I came to in my box.
It seems that for newbies and those unused to arch linux the base install is likely very basic and needs an update before coming more useful. Must admit try to self install drivers etc. looked a bit hard for me as i have difficulty with long multi-document instructions suggested to do it manually. Sorry I could't give credits as names are always a probleem, but for my use case this seems the simplest solution to getting more functunctional. Must admit we mostly feeling our way but a little more detail in some places would be nice.
Apologies for long post but hope it helps someone.
John S
I bought a TL-WN725N too, which is tiny, and a right angle USB-C to A adaptor so I just have one awkward thing protruding from the side of the tablet. Annoying, but not terrible. Worked out of the box using the preinstalled OS (although i had done an update using another adaptor which I already had first).
Just ordered Amazon Basics USB-C to USB-A 3.1 Gen1 Female Adapter Cable Converter and TP-Link AC1300 USB WiFi Adapter(Archer T3U)- 2.4G/5G Dual Band Wireless Network Adapter off Amazon. Should receive them tomorrow and will see how it goes.
A Wifi driver is now available.
See this and the following  posts in the forum here:
https://forum.pine64.org/showthread.php?...#pid121457
  PineTab Bluetooth PimpDiCaprio 0 113 05-29-2024, 11:11 AM
Last Post: PimpDiCaprio
Wink Screen protector for PineTab 2 vatin 0 656 11-18-2023, 01:31 AM
Last Post: vatin
  PineTab 2 (arm64) thoughts and questions acruhl 7 3,210 09-01-2023, 01:13 PM
Last Post: acruhl
  PineTab 2 Dead Screen Kramey 16 5,297 08-12-2023, 05:44 PM
Last Post: Kramey
  pinetab 2 not booting ajhiii070 5 2,053 08-07-2023, 01:46 PM
Last Post: r.aliaskarov
  does the pinetab "just worK"? averageconsumer445 19 5,157 07-15-2023, 10:31 AM
Last Post: dachalife
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,457 07-14-2023, 03:09 AM
Last Post: gregb49
  Pinetab-V shipping Status? jfstepha 6 2,671 07-12-2023, 03:23 PM
Last Post: ChromaticHamster
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 2,519 06-06-2023, 05:26 PM
Last Post: fxc
Star Looking for a Pinetab [EU] Glenn 2 2,744 01-24-2023, 06:12 PM
Last Post: Louis
