Battery that drains even with the Pinphone turned off
So, what's the recommended way to shut down braveheart (1.1) at the moment? Is there a way to send the userspace shutdown to the modem manually and then power down pmos?
(09-26-2020, 04:33 PM)kuleszdl Wrote: So, what's the recommended way to shut down braveheart (1.1) at the moment? Is there a way to send the userspace shutdown to the modem manually and then power down pmos?
Have a try with "poweroff" in terminal?
(I cannot test myself because I do not have braveheart)
sudo poweroff
sudo shutdown now
Or use the equivalent function built into the desktop environment. For example, phosh has a power menu in the top-right.
As mentioned earlier in the thread, do not remove the battery, or operate the modem killswitch, until the PinePhone has been powered down for 30 seconds.
I tried the mentioned actions, however, the system did not shut down properly (it didn't with the powerdown function in the menu, and poweroff in console did not help either).
Another follow-up question: If I disable the modem via killswitch, will I still face these battery drain issues? I'm using my BH pinephone just as a device for testing so I don't really need the modem. On the other side, I don't want to screw the battery...
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 666 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 3,641 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,623 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 4,912 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 1,540 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 27,213 02-26-2022, 02:07 AM
Last Post: vusra
  Battery replacement alternative sax1960 7 6,534 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 2,520 08-15-2021, 07:19 AM
Last Post: bcnaz
  Battery phone case expected? Cpm 1 2,166 08-10-2021, 03:29 PM
Last Post: 33YN2
  Pine Phone Battery Issue vslash 21 19,507 08-09-2021, 07:35 AM
Last Post: mouffa
