Sxmo - Simple X Mobile Released for the Pinephone (new minimalistic UI & image)
#21
So I have successfully re-built sxmo-dwm with new keybindings, but I haven't managed to rebuild lisgd with the new gestures yet.
If anyone wants to play around with the configs, here's what I did:
  • copy the config.def.h file to config.h in each directory and alter the config.h files as you desire
  • copy the directories to your sxmo micro-sd card (I put them in /home/mo/build)
  • boot the phone
  • on the phone, install the build tools and a bunch of libraries needed to build:
         sudo apk add build-base libx11-dev libxft-dev libxinerama-dev libinput-dev eudev-dev
  • enter each directory (lisgd and sxmo-dwm) and type "make install". Don't type "make clean install" because doing so will remove your altered config.h file.
As I mentioned, this has worked for sxmo-dwm, but not lisgd -- yet. But I'm a persistent bastard... (and I'll take any suggestions).
RE: Sxmo - Simple X Mobile Released for the Pinephone (new minimalistic UI & image) - by visiblink - 05-24-2020, 10:54 AM
  PostmarketOS sxmo pinephone keyboard keymaps? afwtioane 2 2,082 09-11-2022, 04:37 AM
Last Post: manubert
  sxmo pim nextcloud Uturn 8 6,153 02-22-2022, 03:23 PM
Last Post: TRS-80
  Battery life on sxmo xark 1 2,118 02-12-2022, 10:07 AM
Last Post: TRS-80
  Official Channels for Sxmo Support anjanmomi 2 3,103 02-12-2022, 09:50 AM
Last Post: TRS-80
  sxmo & php --- 2 1,808 01-31-2022, 01:45 PM
Last Post: ---
  sxmo improvements unrealb2 7 5,751 11-17-2021, 06:43 AM
Last Post: fdlamotte
  SXMO on Debian IVp 0 2,199 08-21-2021, 02:33 PM
Last Post: IVp
  Megi's multiboot sxmo image aithal 1 2,204 06-14-2021, 08:07 AM
  SXMO svkbd with joypad layout [for basic dosbox play] streak 0 1,502 05-27-2021, 08:47 AM
Last Post: streak
  Sxmo on Arch IVp 4 6,472 05-19-2021, 03:18 AM
Last Post: dukla2000
