SXMO on Debian
If anyone wants to try sxmo on Debian, I made a small script that should at least get the basics working. Run this script from phosh or ssh after setting up an internet connection on Mobian ( I used ...phosh-20210516.img.gz ). It's based on an existing script to install sxmo on arch.
Numerous things still do not work. Wifi and (allmost) all on screen input (lisgd and svkbd) work without issues. OTG works, but screen hast to be set up manually. Most apps from the apps list work, but scripts that need sfeed do not. Sound doesn't really work. If you want to have sound, use pulseaudio from the terminal. Suspend doesn't work. Bluetooth is untested. The camera works, because megapixels just works. Modem is untested and most likely doesn't quite work. I want to get sound and suspend (sleep) to work next.
I'm also not sure how long this script will continue to work, since sxmo is moving to tinydm and wayland.
  PostmarketOS sxmo pinephone keyboard keymaps? afwtioane 2 2,061 09-11-2022, 04:37 AM
Last Post: manubert
  sxmo pim nextcloud Uturn 8 6,078 02-22-2022, 03:23 PM
Last Post: TRS-80
  Battery life on sxmo xark 1 2,097 02-12-2022, 10:07 AM
Last Post: TRS-80
  Official Channels for Sxmo Support anjanmomi 2 3,085 02-12-2022, 09:50 AM
Last Post: TRS-80
  sxmo & php --- 2 1,786 01-31-2022, 01:45 PM
Last Post: ---
  sxmo improvements unrealb2 7 5,690 11-17-2021, 06:43 AM
Last Post: fdlamotte
  Megi's multiboot sxmo image aithal 1 2,187 06-14-2021, 08:07 AM
  SXMO svkbd with joypad layout [for basic dosbox play] streak 0 1,489 05-27-2021, 08:47 AM
Last Post: streak
  Sxmo on Arch IVp 4 6,429 05-19-2021, 03:18 AM
Last Post: dukla2000
  Sxmo presentation at AlpineConf 2021 proycon 1 2,127 05-14-2021, 12:56 PM
Last Post: streak
