U-Boot for A64 git
To support the differences between Pine64 and Pine64+ U-Boot needs to be updated. It now detects the model and the default environment will load different device trees (/boot/pine64/sun50i-a64-pine64-plus.dtb, /boot/pine64/sun50i-a64-pine64.dtb).
Get 20160319-1 from https://www.stdin.xyz/downloads/people/l...64-images/
To update both Kernel an U-Boot to the latest releases, run the following commands (as root):
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_uboot.sh)
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh)
and reboot.
If you update the Kernel as well you will get both device trees, making the image also work with networking on the non-plus Pine64 when you remove the fixed dtb filename from the existing /boot/uEnv.txt.
U-Boot for A64 git - by longsleep - 01-09-2016, 01:11 AM
RE: U-Boot for A64 git - by longsleep - 02-07-2016, 11:44 AM
RE: U-Boot for A64 git - by taros - 02-08-2016, 04:48 PM
RE: U-Boot for A64 git - by taros - 02-07-2016, 04:39 PM
RE: U-Boot for A64 git - by longsleep - 02-08-2016, 02:52 PM
RE: U-Boot for A64 git - by longsleep - 02-08-2016, 05:17 PM
RE: U-Boot for A64 git - by patrickhwood - 02-08-2016, 11:08 PM
RE: U-Boot for A64 git - by taros - 02-09-2016, 10:39 AM
RE: U-Boot for A64 git - by longsleep - 02-09-2016, 04:19 PM
RE: U-Boot for A64 git - by longsleep - 02-14-2016, 02:48 AM
RE: U-Boot for A64 git - by longsleep - 02-21-2016, 06:27 AM
RE: U-Boot for A64 git - by longsleep - 02-27-2016, 06:46 AM
RE: U-Boot for A64 git - by tllim - 02-27-2016, 02:14 PM
RE: U-Boot for A64 git - by longsleep - 03-04-2016, 03:23 PM
RE: U-Boot for A64 git - by longsleep - 03-06-2016, 10:09 AM
RE: U-Boot for A64 git - by longsleep - 03-12-2016, 03:25 AM
RE: U-Boot for A64 git - by longsleep - 03-19-2016, 03:40 PM
RE: U-Boot for A64 git - by longsleep - 04-03-2016, 04:59 AM
RE: U-Boot for A64 git - by longsleep - 04-23-2016, 01:29 PM
RE: U-Boot for A64 git - by rahlquist - 04-23-2016, 02:17 PM
RE: U-Boot for A64 git - by rhkean - 04-29-2016, 01:57 PM
RE: U-Boot for A64 git - by longsleep - 04-29-2016, 02:02 PM
RE: U-Boot for A64 git - by rhkean - 04-29-2016, 05:17 PM
RE: U-Boot for A64 git - by rhkean - 04-29-2016, 08:16 PM
RE: U-Boot for A64 git - by rhkean - 05-02-2016, 07:21 AM
RE: U-Boot for A64 git - by spezi - 05-10-2016, 01:13 PM
RE: U-Boot for A64 git - by longsleep - 05-10-2016, 01:29 PM
RE: U-Boot for A64 git - by spezi - 05-11-2016, 01:03 PM
RE: U-Boot for A64 git - by jozzy - 05-12-2016, 02:45 AM
RE: U-Boot for A64 git - by mont3z - 05-29-2016, 10:59 AM
RE: U-Boot for A64 git - by longsleep - 05-29-2016, 11:02 AM
RE: U-Boot for A64 git - by mont3z - 05-29-2016, 08:17 PM
RE: U-Boot for A64 git - by mont3z - 06-02-2016, 12:26 PM
RE: U-Boot for A64 git - by longsleep - 06-19-2016, 09:34 AM
RE: U-Boot for A64 git - by longsleep - 03-11-2017, 12:10 PM
RE: U-Boot for A64 git - by ak_hepcat - 03-21-2017, 12:36 PM
RE: U-Boot for A64 git - by longsleep - 03-21-2017, 01:59 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,258 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 2,618 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 4,440 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 4,320 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 41,647 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 3,813 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 9,763 04-16-2017, 10:21 PM
Last Post: pfeerick
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 6,831 03-20-2017, 03:59 PM
Last Post: rgdonato
  USB OTG Boot devilsclaw 25 39,631 03-01-2017, 03:22 PM
Last Post: CaptainZalo
  How to boot alternative kernel image with u-boot? zhouer 3 6,918 06-27-2016, 04:15 AM
Last Post: ssvb
