U-Boot for A64 git
(02-08-2016, 05:17 PM)longsleep Wrote:
(02-08-2016, 04:48 PM)taros Wrote: I tried both the Ubuntu gcc for arm, and also the one from Linaro.
On the Internet it suggests to use the gcc4 version of the file. However, there is a preprocessor error when making the change.
What version of the gcc-arm-linux-gnueabihf toolchain is that? I use gcc-arm-linux-gnueabihf 4:4.8.2-1 as in the Ubuntu repository (on trusty). So you should try with 4.8 as well and i guess it will work. Let me know.
Update: I see now that i should add some details about the toolchains. For U-Boot and ATF use gcc-arm-linux-gnueabihf 4.8. For Kernel and Busybox use gcc-aarch64-linux-gnu 5.2. Kernel and Busybox might work with older version as well, but i did not test. You cannot compile U-Boot with anything newer than 4.8. I will add details to the docs asap.
I used gcc 5.2.1 (arm-linux-gnueabihf-gcc-5 (Ubuntu 5.2.1-22ubuntu1) 5.2.1 20151010).
I now switched to gcc-4.8-arm-linux-gnueabihf and trying now again.
For the selected compiler to work, it needs a symlink or better use update-alternatives. This is because the compiler has a "-4" appended to the name which messed up cross-compiling.
U-Boot for A64 git - by longsleep - 01-09-2016, 01:11 AM
RE: U-Boot for A64 git - by longsleep - 02-07-2016, 11:44 AM
RE: U-Boot for A64 git - by taros - 02-08-2016, 04:48 PM
RE: U-Boot for A64 git - by taros - 02-07-2016, 04:39 PM
RE: U-Boot for A64 git - by longsleep - 02-08-2016, 02:52 PM
RE: U-Boot for A64 git - by longsleep - 02-08-2016, 05:17 PM
RE: U-Boot for A64 git - by patrickhwood - 02-08-2016, 11:08 PM
RE: U-Boot for A64 git - by taros - 02-09-2016, 10:39 AM
RE: U-Boot for A64 git - by longsleep - 02-09-2016, 04:19 PM
RE: U-Boot for A64 git - by longsleep - 02-14-2016, 02:48 AM
RE: U-Boot for A64 git - by longsleep - 02-21-2016, 06:27 AM
RE: U-Boot for A64 git - by longsleep - 02-27-2016, 06:46 AM
RE: U-Boot for A64 git - by tllim - 02-27-2016, 02:14 PM
RE: U-Boot for A64 git - by longsleep - 03-04-2016, 03:23 PM
RE: U-Boot for A64 git - by longsleep - 03-06-2016, 10:09 AM
RE: U-Boot for A64 git - by longsleep - 03-12-2016, 03:25 AM
RE: U-Boot for A64 git - by longsleep - 03-19-2016, 03:40 PM
RE: U-Boot for A64 git - by longsleep - 04-03-2016, 04:59 AM
RE: U-Boot for A64 git - by longsleep - 04-23-2016, 01:29 PM
RE: U-Boot for A64 git - by rahlquist - 04-23-2016, 02:17 PM
RE: U-Boot for A64 git - by rhkean - 04-29-2016, 01:57 PM
RE: U-Boot for A64 git - by longsleep - 04-29-2016, 02:02 PM
RE: U-Boot for A64 git - by rhkean - 04-29-2016, 05:17 PM
RE: U-Boot for A64 git - by rhkean - 04-29-2016, 08:16 PM
RE: U-Boot for A64 git - by rhkean - 05-02-2016, 07:21 AM
RE: U-Boot for A64 git - by spezi - 05-10-2016, 01:13 PM
RE: U-Boot for A64 git - by longsleep - 05-10-2016, 01:29 PM
RE: U-Boot for A64 git - by spezi - 05-11-2016, 01:03 PM
RE: U-Boot for A64 git - by jozzy - 05-12-2016, 02:45 AM
RE: U-Boot for A64 git - by mont3z - 05-29-2016, 10:59 AM
RE: U-Boot for A64 git - by longsleep - 05-29-2016, 11:02 AM
RE: U-Boot for A64 git - by mont3z - 05-29-2016, 08:17 PM
RE: U-Boot for A64 git - by mont3z - 06-02-2016, 12:26 PM
RE: U-Boot for A64 git - by longsleep - 06-19-2016, 09:34 AM
RE: U-Boot for A64 git - by longsleep - 03-11-2017, 12:10 PM
RE: U-Boot for A64 git - by ak_hepcat - 03-21-2017, 12:36 PM
RE: U-Boot for A64 git - by longsleep - 03-21-2017, 01:59 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,247 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 2,616 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 4,433 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 4,310 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 41,568 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 3,805 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 9,739 04-16-2017, 10:21 PM
Last Post: pfeerick
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 6,817 03-20-2017, 03:59 PM
Last Post: rgdonato
  USB OTG Boot devilsclaw 25 39,607 03-01-2017, 03:22 PM
Last Post: CaptainZalo
  How to boot alternative kernel image with u-boot? zhouer 3 6,915 06-27-2016, 04:15 AM
Last Post: ssvb
