Booting - User device selection in U-Boot?
(06-08-2020, 09:55 AM)Arwen Wrote: Yes, either Grub with menu, or the simple U-Boot device selection would work.
People doing testing could then select which OS to boot. If it fails, no problem,
just reboot and select the working OS and make a change to the one under
test. Then try again.
At present, I don't see Grub getting both text menu, (on the LCD), and keyboard
support, (also the PBP keyboard, not serial console), any time soon. Grub seems
to support such for x86/x64, but that is likely through BIOS calls that don't exist
for any ARM computer.
Thinking about it, I've added ESC & Return keys to the original post, to do the
obvious thing.
I got the PBP keyboard to work with u-boot and grub (using the arm64-efi target). It's as simple as adding a few flags when compiling u-boot to instruct it to enable the necessary USB support, and having "usb start" as part of the boot script (note this does slow down the boot by a second or two). Unfortunately the menu only displays over a serial console since u-boot doesn't know how to initialize LCD.
If anyone has any pointers on how to port the LCD/eDP drivers that linux uses to u-boot I'd love to hear it. The code for both are sooo similar, and unfortunately I wasn't smart enough to figure out the right combination of edits to the u-boot code to make it work (can only make the screen briefly flicker).
RE: Booting - User device selection in U-Boot? - by amiraeva - 06-08-2020, 10:28 AM
  upgrading u-boot--what version? where to get it? bsammon 5 127 7 hours ago
Last Post: dachalife
  uboot wont boot to SD card after upgrade jbradley419 7 1,026 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 335 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,437 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 796 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 654 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,295 09-19-2023, 08:48 AM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,023 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 838 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 2,055 06-14-2023, 07:20 AM
