How to enable SSH on UBPorts Ubuntu Touch?
I've been trying the things mentioned in this thread, but haven't been succesful.
- /etc/ssh/sshd_config cannot be edited, the file system is read only. "It is required for for saving/loading search history or cursor position".
Should I made it read-write? But I keep reading that that's a big no-no?
- sudo service ssh enable
I thought I might set SSH to always run, but that didn't work.
- sudo service ssh start
This seems to do something. I get "ssh start/running, process 8977". But when I tried to connect to the phone I just get "operation timed out".
- "Actually, there's no need to generate a private key on the pinephone if you only intend to connect to it instead from connect from it.
The authorized_keys file is enough".
I tried creating a file called /home/phablet/.shh/authorized_keys, but that had no effect.
- Connect with Wifitransfer.
This never worked for me. I set all the parameters (the app is very clear and seems useful), but Filezilla just times out?
Could someone perhaps share a quick step-by-step beginner friendly guide?
Can I get SSH to just always be enabled?
- What command should I run on my mac to generate keys?
- And then in what directory on the phone should I place them? I suspect its ˜/.shh ?
- Do I then reboot?
- Could there be a firewall blocking things?
And while I'm at it: is there a way to send the CTRL key in the phone's terminal? Without it using Nano is quite difficult.
RE: How to enable SSH on UBPorts Ubuntu Touch? - by eaglecup - 05-20-2020, 03:25 PM
  Ubuntu Touch on Pine64 Rondarius 11 3,609 10-11-2023, 12:36 PM
Last Post: Rondarius
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 5,932 06-26-2023, 07:50 AM
Last Post: gregb49
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 2,907 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 4,998 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
  UB Touch build with debos layton-dev 0 2,265 04-23-2021, 08:12 AM
Last Post: layton-dev
  Ubuntu Touch with OTA updates Luke 131 168,542 04-21-2021, 12:20 PM
Last Post: Nooblife
  online accounts in UBports Uturn 2 4,238 03-30-2021, 09:12 AM
Last Post: Uturn
  UBPorts Not Working Pinoideae 7 9,750 03-13-2021, 01:51 PM
Last Post: KNERD
  Whats the latest with UB touch? Cree 9 11,419 03-11-2021, 10:59 AM
Last Post: andybleaden@gmail.com
  How to enable Ethernet with UBPorts and convergence dock? piney-tim 1 3,065 11-27-2020, 07:40 PM
Last Post: piney-tim
