What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
#95
(01-06-2021, 04:06 AM)4carlos Wrote: I have a brand new Pinephone Manjaro with Phosh Beta 4 and massive stability issues. Every few minutes the screen goes black and I have to log in again.
That is phosh crashing - it isn't the most stable environment but every few minutes is exceptional.
(01-06-2021, 04:06 AM)4carlos Wrote: ..
I found this posting and would like to know whether the solution described can also be used for the Pinephone Manjaro. At the moment I am not that familiar with the system and need a little help with it. I can flash the * .bin files (as described), but the Pinephone does not boot afterwards.
For which system are the "patches" intended? PostmarketOS, Manjaro, Mobian or others? Which versions are they suitable for? How exactly do I have to use them (step by step) would be welcome.
The patches are relevant to any of the images, however, a simpler up front trial would be to download/install Mobian on an SDcard and try that. The reason I suggest Mobian is if anything it probably has the least aggressive memory speed compared to the others. But in fact if you run a release from SDcard you avoid the whole eMMC speed anyway.
Once you have a bit more confidence in your phone then you can decide if you want to try Manjaro from the eMMC again, or carry on with Mobian or whatever.
RE: [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes - by dukla2000 - 01-06-2021, 02:27 PM
  emmc speed via usb? joe1 0 127 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 817 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 5,109 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 5,715 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 6,480 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 4,189 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 6,280 06-22-2020, 09:20 AM
Last Post: Nooblife
