Crashes in every OS - Hardware-issue?
Sad
Hey there,
my PinePhone CE crashed in every system I tested (UBports, Manjaro, Mobian, Sailfish, ...). Sometimes it is running some hours, sometimes it crashes after some minutes. I thought it could be a RAM-problem but I only found memtester as userspace-application which gives no exhaustive result.
Could it be my device has an hardware-issue? How can I test? The phone also gets often really hot. Might also be there is a heatproblem.
I don't know how to go further. I'd really love to use the PP als daily driver but It is not usable this way for me Sad
Any help and hints welcome!
I'm almost certain it'll be the DRAM issue.
I had a similar issue (instability on all OS images).
I patched with the uboot adjustment available on the post on this forum and have not had a single crash since.
can you link the post about the uboot adjustment? I can't find it.
(06-22-2020, 06:22 AM)Bouc Wrote: Hi,
Have a look here
I only get crashes in ubports, does it run at a higher clock speed than mobian?
  Microphone on Hardware Model 1.2 is Unusably Noisy In Some Circomstances ASmartSuitedSimpleton 4 3,630 03-23-2024, 10:55 AM
Last Post: Ferriah
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,413 03-20-2023, 12:54 AM
Last Post: bcoyle
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 4,100 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Is the hardware still being developed and refined? orbital 10 4,692 09-01-2022, 08:05 PM
Last Post: orbital
  How to check hardware revision? jojuma 1 1,502 07-16-2022, 12:28 AM
Last Post: bokomaru
  Odd Issue CzarD0mn 3 2,174 06-12-2022, 02:36 PM
Last Post: alaraajavamma
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,497 05-31-2022, 06:41 PM
Last Post: SwordfishII
Lightbulb [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes devrtz 108 131,621 04-20-2022, 11:44 AM
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 5,708 04-19-2022, 02:36 PM
Last Post: kk22
  Hardware switch for mic is not working properly submariner 10 7,357 01-25-2022, 07:01 AM
Last Post: wibble
