What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
#21
So, maybe I'm dumb and doing this wrong, but can I just replace the u-boot bin file in /usr/share/u-boot on the sd card with the new bin file and it just works when I boot from the sd card?
Cause I have a bad black screen issue and figured I'd try this, but mine happens live and usually after I touch the touchscreen. So, I don't know if it's this issue, but I'm trying to test it and see. So I'm not sure if I need to run the dd script or if the file getting replaced will do the job.
Thanks for the help!
RE: [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes - by gotomech - 05-19-2020, 01:05 PM
  emmc speed via usb? joe1 0 50 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 662 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 4,987 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 5,597 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 6,356 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 4,128 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 6,158 06-22-2020, 09:20 AM
Last Post: Nooblife
