What is the highest usable DRAM clock speed for you?
552
29.17%
7
564
0%
0
576
12.50%
3
588
8.33%
2
600
4.17%
1
612
8.33%
2
624
37.50%
9
24 vote(s)
[Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes
I like the debs makes it really easy to dl and install via ssh.
A nice tool would be a control center with things like temps and throttle limits as well as config values or sliders for the various clock speeds on different components.
In the N900 days we have a few apps like this which would let us set swap values(only 256mb RAM!!), and other tools which would let us tweak the CPU and and GPU.
The GPU tweak will become important as more apps are built with opengl using the GPU.
As for the speed I installed 588mhz deb though I suspect my random crashes are more related to running the CPU hot trying to use Firefox to check webmail than memory.
RE: [Volunteer needed]Too high DRAM clock speed MAY be causing you random crashes/freezes - by biketool - 04-20-2022, 11:44 AM
  emmc speed via usb? joe1 0 44 04-27-2024, 08:07 PM
Last Post: joe1
  Phone powers off with high user demands car46999 7 625 04-11-2024, 09:17 AM
Last Post: zetabeta
  Help needed: Jump drive not working UsnR2 5 4,975 07-09-2021, 03:22 PM
Last Post: UsnR2
  Endless crashes on Pine64 received today luciphercolors 4 5,589 11-24-2020, 06:09 PM
Last Post: rocket2nfinity
  Does the PinePhone have a hardware random number generator? LibrePhoneUser 4 6,352 11-12-2020, 07:47 PM
Last Post: megous
  Only enable modem when needed with kill switches sokolgeo 2 4,118 09-20-2020, 04:40 AM
Last Post: sokolgeo
Sad Crashes in every OS - Hardware-issue? rakor 4 6,151 06-22-2020, 09:20 AM
Last Post: Nooblife
