USB Wifi drivers avail in new kernel (3.10.101-0-pine64-longsleep)
(05-07-2016, 07:37 AM)rahlquist Wrote: Ok quick guide with some of the basics. I am using longlseeps kernel on debian.
(Lots of words)
Thanks, man.
I tinkered around a bit with this, but as I don't have the wifi/bt board available yet, I tested with an USB Wifi-dongle I've had lying around (a Netgear WNA-3100M). After the updates, my kernel actually replied that WTF-message and prompted me to install realtek-firmware package.
I DuckDuckWent there from Midori and found this realtek-firmware install howto which worked wonders. I unplugged and replugged the device after the package was installed (sudo apt-get install realtek-firmware) and woop-de-doo! WiFi!
dmesg output:
[  226.242969] ehci_irq: highspeed device connect
[  226.459751] usb 1-1: new high-speed USB device number 3 using sunxi-ehci
[  226.610842] rtl8192cu: Chip version 0x11
[  226.723156] rtl8192cu: MAC address: a4:2b:8c:5e:33:e1
[  226.723181] rtl8192cu: Board Type 0
[  226.723505] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[  226.723652] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[  226.770856] rtlwifi: Loading alternative firmware rtlwifi/rtl8192cufw.bin
[  226.770871] rtlwifi: Firmware rtlwifi/rtl8192cufw_TMSC.bin not available
Installed driver, unplugged and replugged:
[  490.072514] ehci_irq: highspeed device disconnect
[  490.072642] usb 1-1: USB disconnect, device number 3
[  491.817477] ehci_irq: highspeed device connect
[  492.042864] usb 1-1: new high-speed USB device number 4 using sunxi-ehci
[  492.195924] rtl8192cu: Chip version 0x11
[  492.308508] rtl8192cu: MAC address: a4:2b:8c:5e:33:e1
[  492.308535] rtl8192cu: Board Type 0
[  492.308833] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[  492.308978] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[  492.344507] ieee80211 phy2: Selected rate control algorithm 'rtl_rc'
[  492.346360] rtlwifi: wireless switch is on
[  493.435815] rtl8192cu: MAC auto ON okay!
RE: USB Wifi drivers avail in new kernel (3.10.101-0-pine64-longsleep) - by CaptainZalo - 05-08-2016, 03:16 PM
  [split] Better WiFi/BT module? moriel5 3 5,116 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,813 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 25,275 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 4,208 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 27,211 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,845 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 3,609 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,992 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,111 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 5,455 12-29-2016, 10:26 AM
Last Post: happytuna
