Netflix, state of the art?
#71
(08-09-2020, 02:48 PM)TheBackburner Wrote:
(07-30-2020, 12:03 PM)spikerguy Wrote: Hello,
Can you provide some logs so someone can look into it and know what might be causing the issue.
Please share the output of the logs when it is trying to install the package.
Sorry for the inconvenience caused.
@spikerguy , is what you need the output when trying to run chromium-docker? If so, see below:
Enabling XHost Forwarding
non-network local connections being added to access control list
Searching for Docker image ...
Found and using d7150613eb67
/usr/bin/chromium-browser: line 133: lsb_release: command not found
/usr/bin/chromium-browser: line 134: lsb_release: command not found
[1:1:0809/202837.988206:ERROR:process_singleton_posix.cc(294)] The profile appears to be in use by another Chromium process (1) on another computer (1851c23db1a3). Chromium has locked the profile so that it doesn't get corrupted. If you are sure no other processes are using this profile, you can unlock the profile and relaunch Chromium.
../../sandbox/linux/seccomp-bpf-helpers/sigsys_handlers.cc:**CRASHING**:seccomp-bpf failure in syscall 0403
[1:21:0809/202845.472653:FATAL:gpu_data_manager_impl_private.cc(986)] The display compositor is frequently crashing. Goodbye.
If there's something else needed, could you help me out with what commands or program I would need to run to get the output you're looking for? I'm a bit of a Linux noob, so I'm not even sure what providing logs entails, and I didn't have much success Googling the topic. I'd love to get this program running again, so I'd be happy to provide any output you might need. Please let me know what I can do to help. Thanks!
Thanks for reporting, I am testing it now. A quick search shows that it needs a newer chromium version. I will try to update it and test it.
If everything goes well then will push the updated version of the package.
UPDATE:
Chromium on docker is fixed now.
Moved base to ubuntu bionic latest, Updated Chromium to version 84 and now volume control from host machine works but needs paprefs package.
For those who are having issue with chromium on docker please do the following.
This will remove all the docker images do please DO NOT DO THIS IF YOU HAVE OTHER DOCKER IMAGES ON YOUR SYSTEM, instead manually remove the chromiun docker image.
docker system prune -a --volumes
Next is to remove old chromium-docker as the files are saved locally.
sudo pacman -R chromium-docker
Now you can install the app again, using
sudo pacman -S chromium-docker
Can anyone do the following and report if netflix and amazon works or not as my accounts have expired so I cannot test it. I tested youtube over chromiun-docker updated app and it works fine again.
UPDATE:
Added pulseaudio handling over network so paprefs becomes a dependency which will be installed but user will have to enable it
Open paprefs - sound server preference
and just enable as per the below pic.
[img]data:image/png;base64,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[/img]
Thanks.
Manjaro ARM Team.
Netflix, state of the art? - by gleachkr - 04-17-2020, 11:27 AM
Netflix, state of the art? - by hthiemann - 04-18-2020, 01:48 AM
RE: Netflix, state of the art? - by PakoSt - 04-18-2020, 07:47 AM
RE: Netflix, state of the art? - by gleachkr - 04-18-2020, 10:11 AM
Netflix, state of the art? - by hthiemann - 04-19-2020, 01:14 PM
RE: Netflix, state of the art? - by PakoSt - 04-19-2020, 04:18 PM
RE: Netflix, state of the art? - by Eight Bit - 04-20-2020, 11:37 AM
RE: Netflix, state of the art? - by 8-bit - 04-19-2020, 05:42 PM
RE: Netflix, state of the art? - by PakoSt - 04-19-2020, 06:44 PM
RE: Netflix, state of the art? - by hthiemann - 04-20-2020, 12:41 PM
RE: Netflix, state of the art? - by spikerguy - 04-20-2020, 03:54 PM
RE: Netflix, state of the art? - by Luke - 04-20-2020, 03:57 PM
RE: Netflix, state of the art? - by PakoSt - 04-20-2020, 01:41 PM
RE: Netflix, state of the art? - by PakoSt - 04-20-2020, 05:59 PM
RE: Netflix, state of the art? - by appelgriebsch - 04-23-2020, 01:29 AM
RE: Netflix, state of the art? - by hthiemann - 04-21-2020, 12:56 AM
RE: Netflix, state of the art? - by Eight Bit - 04-22-2020, 07:47 AM
RE: Netflix, state of the art? - by hthiemann - 04-23-2020, 01:55 AM
RE: Netflix, state of the art? - by PakoSt - 04-23-2020, 06:10 AM
RE: Netflix, state of the art? - by appelgriebsch - 04-23-2020, 10:47 AM
RE: Netflix, state of the art? - by PakoSt - 04-23-2020, 05:56 PM
RE: Netflix, state of the art? - by PakoSt - 04-24-2020, 02:29 AM
RE: Netflix, state of the art? - by hthiemann - 04-24-2020, 07:17 AM
RE: Netflix, state of the art? - by PakoSt - 04-24-2020, 01:43 PM
RE: Netflix, state of the art? - by spikerguy - 04-24-2020, 03:26 PM
RE: Netflix, state of the art? - by hthiemann - 04-25-2020, 05:12 AM
RE: Netflix, state of the art? - by gleachkr - 04-25-2020, 12:58 PM
RE: Netflix, state of the art? - by PakoSt - 04-25-2020, 02:01 PM
RE: Netflix, state of the art? - by PakoSt - 04-26-2020, 04:13 AM
RE: Netflix, state of the art? - by spikerguy - 04-26-2020, 08:00 AM
RE: Netflix, state of the art? - by PakoSt - 04-26-2020, 03:18 PM
RE: Netflix, state of the art? - by gleachkr - 04-26-2020, 04:09 PM
RE: Netflix, state of the art? - by spikerguy - 04-27-2020, 12:02 PM
RE: Netflix, state of the art? - by gleachkr - 04-28-2020, 01:10 PM
RE: Netflix, state of the art? - by spikerguy - 04-30-2020, 07:05 AM
RE: Netflix, state of the art? - by spikerguy - 04-30-2020, 04:58 PM
RE: Netflix, state of the art? - by pfeerick - 05-01-2020, 03:02 AM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 12:29 PM
RE: Netflix, state of the art? - by kervel - 05-28-2020, 01:58 PM
RE: Netflix, state of the art? - by appelgriebsch - 07-16-2020, 01:26 AM
RE: Netflix, state of the art? - by mkdent - 07-17-2020, 10:26 PM
RE: Netflix, state of the art? - by appelgriebsch - 07-18-2020, 12:24 AM
RE: Netflix, state of the art? - by TonGruter - 07-28-2020, 02:27 PM
RE: Netflix, state of the art? - by spikerguy - 07-30-2020, 12:03 PM
RE: Netflix, state of the art? - by TheBackburner - 08-09-2020, 02:48 PM
RE: Netflix, state of the art? - by spikerguy - 08-14-2020, 06:28 AM
RE: Netflix, state of the art? - by appelgriebsch - 09-06-2020, 11:42 PM
RE: Netflix, state of the art? - by User 18041 - 09-09-2020, 08:44 AM
RE: Netflix, state of the art? - by spikerguy - 09-09-2020, 11:45 AM
RE: Netflix, state of the art? - by User 18041 - 09-10-2020, 03:36 AM
RE: Netflix, state of the art? - by wrzomar - 09-26-2020, 12:05 PM
RE: Netflix, state of the art? - by spikerguy - 10-11-2020, 04:04 AM
RE: Netflix, state of the art? - by PakoSt - 05-02-2020, 04:08 PM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 06:31 PM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 06:54 PM
RE: Netflix, state of the art? - by pfeerick - 05-03-2020, 06:17 AM
RE: Netflix, state of the art? - by whiskey - 05-03-2020, 08:02 AM
RE: Netflix, state of the art? - by Eight Bit - 05-03-2020, 09:28 AM
RE: Netflix, state of the art? - by spikerguy - 05-03-2020, 06:48 PM
RE: Netflix, state of the art? - by pfeerick - 05-04-2020, 06:39 AM
RE: Netflix, state of the art? - by spikerguy - 05-04-2020, 10:35 AM
RE: Netflix, state of the art? - by Eight Bit - 05-04-2020, 03:42 PM
RE: Netflix, state of the art? - by spikerguy - 05-06-2020, 02:19 AM
RE: Netflix, state of the art? - by Eight Bit - 05-07-2020, 03:48 AM
RE: Netflix, state of the art? - by spikerguy - 05-08-2020, 07:38 AM
RE: Netflix, state of the art? - by spikerguy - 05-20-2020, 10:25 PM
RE: Netflix, state of the art? - by Luke - 05-21-2020, 04:26 AM
RE: Netflix, state of the art? - by erchache2000 - 05-22-2020, 04:24 PM
RE: Netflix, state of the art? - by koparthur - 05-31-2020, 08:41 AM
RE: Netflix, state of the art? - by spikerguy - 05-31-2020, 02:12 PM
RE: Netflix, state of the art? - by koparthur - 05-31-2020, 03:55 PM
RE: Netflix, state of the art? - by spikerguy - 06-01-2020, 05:08 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 02:53 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 03:59 AM
RE: Netflix, state of the art? - by appelgriebsch - 07-18-2020, 04:37 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 07:40 AM
RE: Netflix, state of the art? - by wrzomar - 10-13-2020, 06:11 AM
RE: Netflix, state of the art? - by Mangled - 10-27-2020, 10:20 AM
RE: Netflix, state of the art? - by monty11ez - 11-25-2020, 05:28 PM
RE: Netflix, state of the art? - by wrzomar - 03-24-2021, 03:42 PM
  Funny Conky like script to monitor your PBP state as400 1 3,311 08-19-2020, 12:57 PM
Last Post: xmixahlx
  Netflix on default Chromium/Debian MoonDog 8 10,294 01-28-2020, 04:58 AM
Last Post: simeon
  State of hibernate or hybrid-sleep? Arwen 5 7,504 11-21-2019, 07:51 AM
