Netflix, state of the art?
#61
(07-16-2020, 01:26 AM)@appelgriebsch I do like this idea, too. I tried it out, but get an error message concerning ChromeOs. Wrote:
Directory /var/lib/machines/chromium_widevine doesn't look like it has an OS tree. Refusing.
Do you know  how to solve this?
Löse Unterschiede auf: 100% (109/109), Fertig.
  -> Downloading ChromeOS image...
  % Total    % Received % Xferd  Average Speed  Time    Time    Time  Current
                                Dload  Upload  Total  Spent    Left  Speed
100  976M  100  976M    0    0  1793k      0  0:09:17  0:09:17 --:--:-- 3314k
  -> Mounting local ChromeOS image...
  -> Setting up environment in systemd container chromium_widevine...
  -> Cleaning up...
==> All done! You can use the launcher to start the Chromium Widevine application
[root@michihost Downloads]# machinectl start chromium_widevine
Invalid machine name chromium_widevine.
[root@michihost Downloads]# ./launch_chromium_widevine.sh
non-network local connections being added to access control list
appelgriebsch
(05-28-2020, 01:58 PM)kervel Wrote: Hello,
i think it should be possible to get rid of docker completely using debootstrap.
I got google chrome running as follows:
mkdir deb
debootstrap --arch=armhf buster deb
cp deb/lib/ld-linux-armhf.so.3 /lib
sudo chroot deb /bin/bash
Now inside the chroot i edited /etc/apt/sources.list to enable non-free and contrib and then i was able to do apt update && apt install chromium.
Once this is done, one can launch chromium as follows:
LD_LIBRARY_PATH=$PWD/lib:$PWD/usr/lib/:$PWD/usr/lib/arm-linux-gnueabihf/:\
$PWD/lib/arm-linux-gnueabihf/:$PWD/usr/lib/arm-linux-gnueabihf/pulseaudio/ \
usr/lib/chromium/chromium
this is without docker or chroot or x forwarding ..
Hey,
I just did this based on a systemd-nspawn container following the guides here:
Works pretty well and doesn't need a docker daemon running in the background. My scripts for integration in Manjaro:
Like this idea much better than the docker image approach...
Netflix, state of the art? - by gleachkr - 04-17-2020, 11:27 AM
Netflix, state of the art? - by hthiemann - 04-18-2020, 01:48 AM
RE: Netflix, state of the art? - by PakoSt - 04-18-2020, 07:47 AM
RE: Netflix, state of the art? - by gleachkr - 04-18-2020, 10:11 AM
Netflix, state of the art? - by hthiemann - 04-19-2020, 01:14 PM
RE: Netflix, state of the art? - by PakoSt - 04-19-2020, 04:18 PM
RE: Netflix, state of the art? - by Eight Bit - 04-20-2020, 11:37 AM
RE: Netflix, state of the art? - by 8-bit - 04-19-2020, 05:42 PM
RE: Netflix, state of the art? - by PakoSt - 04-19-2020, 06:44 PM
RE: Netflix, state of the art? - by hthiemann - 04-20-2020, 12:41 PM
RE: Netflix, state of the art? - by spikerguy - 04-20-2020, 03:54 PM
RE: Netflix, state of the art? - by Luke - 04-20-2020, 03:57 PM
RE: Netflix, state of the art? - by PakoSt - 04-20-2020, 01:41 PM
RE: Netflix, state of the art? - by PakoSt - 04-20-2020, 05:59 PM
RE: Netflix, state of the art? - by appelgriebsch - 04-23-2020, 01:29 AM
RE: Netflix, state of the art? - by hthiemann - 04-21-2020, 12:56 AM
RE: Netflix, state of the art? - by Eight Bit - 04-22-2020, 07:47 AM
RE: Netflix, state of the art? - by hthiemann - 04-23-2020, 01:55 AM
RE: Netflix, state of the art? - by PakoSt - 04-23-2020, 06:10 AM
RE: Netflix, state of the art? - by appelgriebsch - 04-23-2020, 10:47 AM
RE: Netflix, state of the art? - by PakoSt - 04-23-2020, 05:56 PM
RE: Netflix, state of the art? - by PakoSt - 04-24-2020, 02:29 AM
RE: Netflix, state of the art? - by hthiemann - 04-24-2020, 07:17 AM
RE: Netflix, state of the art? - by PakoSt - 04-24-2020, 01:43 PM
RE: Netflix, state of the art? - by spikerguy - 04-24-2020, 03:26 PM
RE: Netflix, state of the art? - by hthiemann - 04-25-2020, 05:12 AM
RE: Netflix, state of the art? - by gleachkr - 04-25-2020, 12:58 PM
RE: Netflix, state of the art? - by PakoSt - 04-25-2020, 02:01 PM
RE: Netflix, state of the art? - by PakoSt - 04-26-2020, 04:13 AM
RE: Netflix, state of the art? - by spikerguy - 04-26-2020, 08:00 AM
RE: Netflix, state of the art? - by PakoSt - 04-26-2020, 03:18 PM
RE: Netflix, state of the art? - by gleachkr - 04-26-2020, 04:09 PM
RE: Netflix, state of the art? - by spikerguy - 04-27-2020, 12:02 PM
RE: Netflix, state of the art? - by gleachkr - 04-28-2020, 01:10 PM
RE: Netflix, state of the art? - by spikerguy - 04-30-2020, 07:05 AM
RE: Netflix, state of the art? - by spikerguy - 04-30-2020, 04:58 PM
RE: Netflix, state of the art? - by pfeerick - 05-01-2020, 03:02 AM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 12:29 PM
RE: Netflix, state of the art? - by kervel - 05-28-2020, 01:58 PM
RE: Netflix, state of the art? - by appelgriebsch - 07-16-2020, 01:26 AM
RE: Netflix, state of the art? - by mkdent - 07-17-2020, 10:26 PM
RE: Netflix, state of the art? - by appelgriebsch - 07-18-2020, 12:24 AM
RE: Netflix, state of the art? - by TonGruter - 07-28-2020, 02:27 PM
RE: Netflix, state of the art? - by spikerguy - 07-30-2020, 12:03 PM
RE: Netflix, state of the art? - by TheBackburner - 08-09-2020, 02:48 PM
RE: Netflix, state of the art? - by spikerguy - 08-14-2020, 06:28 AM
RE: Netflix, state of the art? - by appelgriebsch - 09-06-2020, 11:42 PM
RE: Netflix, state of the art? - by User 18041 - 09-09-2020, 08:44 AM
RE: Netflix, state of the art? - by spikerguy - 09-09-2020, 11:45 AM
RE: Netflix, state of the art? - by User 18041 - 09-10-2020, 03:36 AM
RE: Netflix, state of the art? - by wrzomar - 09-26-2020, 12:05 PM
RE: Netflix, state of the art? - by spikerguy - 10-11-2020, 04:04 AM
RE: Netflix, state of the art? - by PakoSt - 05-02-2020, 04:08 PM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 06:31 PM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 06:54 PM
RE: Netflix, state of the art? - by pfeerick - 05-03-2020, 06:17 AM
RE: Netflix, state of the art? - by whiskey - 05-03-2020, 08:02 AM
RE: Netflix, state of the art? - by Eight Bit - 05-03-2020, 09:28 AM
RE: Netflix, state of the art? - by spikerguy - 05-03-2020, 06:48 PM
RE: Netflix, state of the art? - by pfeerick - 05-04-2020, 06:39 AM
RE: Netflix, state of the art? - by spikerguy - 05-04-2020, 10:35 AM
RE: Netflix, state of the art? - by Eight Bit - 05-04-2020, 03:42 PM
RE: Netflix, state of the art? - by spikerguy - 05-06-2020, 02:19 AM
RE: Netflix, state of the art? - by Eight Bit - 05-07-2020, 03:48 AM
RE: Netflix, state of the art? - by spikerguy - 05-08-2020, 07:38 AM
RE: Netflix, state of the art? - by spikerguy - 05-20-2020, 10:25 PM
RE: Netflix, state of the art? - by Luke - 05-21-2020, 04:26 AM
RE: Netflix, state of the art? - by erchache2000 - 05-22-2020, 04:24 PM
RE: Netflix, state of the art? - by koparthur - 05-31-2020, 08:41 AM
RE: Netflix, state of the art? - by spikerguy - 05-31-2020, 02:12 PM
RE: Netflix, state of the art? - by koparthur - 05-31-2020, 03:55 PM
RE: Netflix, state of the art? - by spikerguy - 06-01-2020, 05:08 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 02:53 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 03:59 AM
RE: Netflix, state of the art? - by appelgriebsch - 07-18-2020, 04:37 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 07:40 AM
RE: Netflix, state of the art? - by wrzomar - 10-13-2020, 06:11 AM
RE: Netflix, state of the art? - by Mangled - 10-27-2020, 10:20 AM
RE: Netflix, state of the art? - by monty11ez - 11-25-2020, 05:28 PM
RE: Netflix, state of the art? - by wrzomar - 03-24-2021, 03:42 PM
  Funny Conky like script to monitor your PBP state as400 1 3,308 08-19-2020, 12:57 PM
Last Post: xmixahlx
  Netflix on default Chromium/Debian MoonDog 8 10,278 01-28-2020, 04:58 AM
Last Post: simeon
  State of hibernate or hybrid-sleep? Arwen 5 7,500 11-21-2019, 07:51 AM
