ARM v8 learning setup
(04-08-2020, 10:49 PM)z4v4l Wrote: right, learning armv8 is only possible with a board starting at 750$ (without memory and requiring a lot of other stuff to buy, that probably double the price), but with x4 10 GBE SFP+ connectors, without such a load learning armv8 doesn't happen... no matter the arm core is the same cortex-a72. if you wanted to shock the OP, there are some ThunderX2 based machines, even hairier and pricier, but honestly such suggestions look like fart in the puddle.
I am not shocked by the price point as I am aware of this. The problem is whether I should instead of I could. You know, when you got a driving license, it is better to f__k with a HIACE to start with rather than fooling around with a Maserati and crash it in no time.
(04-08-2020, 08:50 PM)xmixahlx Wrote: there are better ways to learn armv8/arm64 than a pbp. if you are asking about 16gb ram you dont know... several of these soc are fixed at 4gb ram. including rk3399.
if you actually want to learn armv8 for development than get a honeycomb lx2k.
Yes, you are right. There are indeed better ways to learn about arm64. Here says,
Quote:The huge advantage of QEMU over VirtualBox is that is supports cross arch simulation, e.g. simulate an ARM guest on an x86 host.
ARM v8 learning setup - by the_hiacer - 04-05-2020, 04:12 AM
RE: ARM v8 learning setup - by Arwen - 04-05-2020, 12:36 PM
RE: ARM v8 learning setup - by the_hiacer - 04-08-2020, 07:24 PM
RE: ARM v8 learning setup - by xmixahlx - 04-08-2020, 08:50 PM
RE: ARM v8 learning setup - by z4v4l - 04-08-2020, 10:49 PM
RE: ARM v8 learning setup - by the_hiacer - 04-09-2020, 04:12 AM
RE: ARM v8 learning setup - by cirosantilli - 04-20-2020, 01:31 AM
RE: ARM v8 learning setup - by xmixahlx - 04-20-2020, 06:29 PM
  Deep Learning Framework Hemingway 2 3,477 06-22-2020, 04:34 PM
Last Post: Hemingway
  Pinebook Pro - wireless connection setup help barn 3 6,276 05-29-2020, 07:35 AM
Last Post: tibuka
