ARM v8 learning setup
Hi Pine64ers,
I would like to buy a PBP primarily for learning the ARM v8 architecture.
My initial thinking is to do some kernel hacking of some open source OS. In terms of learning, which OS should I go for? In some BSD documents, it takes two identical machines with their com port connected and use the debugger to step through the kernel execution. Is this the case for PBP? If so, how could that be done? If this is not the way to do it, what is the recommended way?
My primary objective is learning the ARM v8 architecture. So things like performance and security is not a concern - at least for now.
Thanks community.
Another quick question: Is it possible to use 8G or even 16G RAM with the PBP?
ARM v8 learning setup - by the_hiacer - 04-05-2020, 04:12 AM
RE: ARM v8 learning setup - by Arwen - 04-05-2020, 12:36 PM
RE: ARM v8 learning setup - by the_hiacer - 04-08-2020, 07:24 PM
RE: ARM v8 learning setup - by xmixahlx - 04-08-2020, 08:50 PM
RE: ARM v8 learning setup - by z4v4l - 04-08-2020, 10:49 PM
RE: ARM v8 learning setup - by the_hiacer - 04-09-2020, 04:12 AM
RE: ARM v8 learning setup - by cirosantilli - 04-20-2020, 01:31 AM
RE: ARM v8 learning setup - by xmixahlx - 04-20-2020, 06:29 PM
  Deep Learning Framework Hemingway 2 3,428 06-22-2020, 04:34 PM
Last Post: Hemingway
  Pinebook Pro - wireless connection setup help barn 3 6,151 05-29-2020, 07:35 AM
Last Post: tibuka
