wlr-randr PMOS + Phosh
(04-03-2020, 01:51 AM)nieral Wrote:
(04-01-2020, 05:59 PM)MartijnBraam Wrote: That can be done by editing /etc/phosh/rootston.ini, there should be scale setting in that file.
So, strange thing: There is no "/etc/phosh/" subfolder, although "phosh-0.2.1-r0" is installed on the system.
I found it in /usr/share/phosh/rootston.ini
If you change
[output:DSI-1]
scale = 2
to 1 or 1.5, you get a higher screen resolution.
However, some screen elements seem to flicker slightly and not everything is distributed optimally. For instance, the keyboard is now narrower than the screen width.
Nevertheless, I consider this a huge improvement!
Martijn, you put out a gnome version of PMOS at the end of February, but this was also lowres, with elements running off the screen. Is there a similar setting to tweak it? I searched but could not find one.
Many thanks for what you have done so far!
wlr-randr PMOS + Phosh - by nieral - 03-29-2020, 03:25 PM
RE: wlr-randr PMOS + Phosh - by Zweitaktmotor - 03-29-2020, 03:47 PM
RE: wlr-randr PMOS + Phosh - by PureTryOut - 03-30-2020, 08:43 AM
RE: wlr-randr PMOS + Phosh - by nieral - 03-30-2020, 12:34 PM
RE: wlr-randr PMOS + Phosh - by PureTryOut - 03-31-2020, 01:41 AM
RE: wlr-randr PMOS + Phosh - by nieral - 03-31-2020, 01:59 PM
RE: wlr-randr PMOS + Phosh - by MartijnBraam - 04-01-2020, 05:59 PM
RE: wlr-randr PMOS + Phosh - by nieral - 04-03-2020, 01:51 AM
RE: wlr-randr PMOS + Phosh - by Zweitaktmotor - 04-04-2020, 06:37 PM
RE: wlr-randr PMOS + Phosh - by nieral - 04-02-2020, 12:21 AM
  Fresh install pmos+phosh does not boot user641 1 509 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 2,132 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Boots To Shell After Dead Battery (PMOS) britelite 0 724 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,894 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 5,561 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 1,384 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,699 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 6,234 02-03-2022, 09:14 PM
Last Post: parry
  Application list PMOS-Phosh jmorris 6 6,176 12-04-2021, 02:26 AM
Last Post: Juergen
  Phosh beta 10, no send button on Chatty? Rainer 0 1,635 05-24-2021, 08:17 AM
Last Post: Rainer
