This is how you flash to eMMC easily
#26
(03-16-2020, 02:25 PM)Luke Wrote: Hello everyone,
We now have a utility to flash eMMC. Many thanks go out to @MartijnBraam @Danct12 and others who contributed to making this happen.
Here's how it works:
1) download the Jumpdrive image
2) flash the Jumpdrive image to a SD card
3) boot from the SD card
4) connect the PinePhone to your computer using USB-A -> USB-C cable.
5) flash the exposed (mounted) PinePhone drive with a chosen OS image as you'd flash any SD card
6) once the flashing process is complete, disconnect the PinePhone from your PC, power it down and remove the Jumpdrive SD card
7) boot into your OS of choice on eMMC
Thanks to everyone who put this together.  I downloaded the Mobian/Posh beta and installed it to the using this procedure and the built in Disks utility in Mint to flash both Jumpdrive to the 4gb MicroSD I used to boot the Pinephone Beta (3gb) and then to eMMC.
No issues at all with the reflash and the end result is far faster and more usable than Manjaro/KDE.
This is how you flash to eMMC easily - by Luke - 03-16-2020, 02:25 PM
RE: This is how you flash to eMMC easily - by Old_Mil - 07-08-2021, 06:32 PM
RE: This is how you flash to eMMC easily - by fxc - 11-17-2022, 11:36 AM
RE: This is how you flash to eMMC easily - by fxc - 11-24-2022, 06:51 AM
RE: This is how you flash to eMMC easily - by fxc - 11-24-2022, 02:33 PM
RE: This is how you flash to eMMC easily - by fxc - 12-25-2022, 05:13 PM
  install iso from sd card to emmc aular 2 433 03-11-2024, 10:24 PM
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,538 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 1,864 04-21-2023, 12:37 AM
Last Post: Uturn
  trouble flashing eMMC TylerBlackberry 3 1,296 04-13-2023, 05:55 AM
  emmc formatted by mistake (it no longer appears) elode 5 3,278 07-12-2022, 04:33 AM
Last Post: elode
  Tow Boot - How to Flash a New OS? arkadione 3 2,849 06-15-2022, 04:10 PM
Last Post: kmsgli
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 1,403 05-31-2022, 04:26 PM
Last Post: fxc
  no emmc after flash ragele 3 2,298 05-30-2022, 04:26 AM
Last Post: fxc
  eMMC label gilwood 1 2,270 12-31-2021, 06:25 PM
Last Post: moonwalkers
  Cannot Create Profile - Cannot even Flash OS absolutenoob 6 5,448 12-17-2021, 03:52 AM
Last Post: guenther
